Ride height - modified rear camber trailing arms
A couple of year ago I bought 3 deg neg camber trailing arms from cbf450 (I think he's called) but i forgot that ride height the arms are made for.
Right now one pair (ive got two pairs) are on the slammed car but there are too much toe in.. Does anyone know the ride height or how I can contact cbf450? Smile
Cheers
just jack up the rear of the car until the wheels have the right toe in then measure up the distance between tyre/arch and that will give you your needed ride height
I've tried that and the car looks 40-50mm higher than the other cars with the modified trailing arms..
Richw (from the 306gti6 forum) may also know because he had those arms on his high boost 306.
  Spring height Tidoh2016 3 4,066 07-11-2018, 01:41 PM
  changing gear selector arms. Chris_90 2 2,579 29-09-2016, 01:52 PM
Last Post: Chris_90
  Lower Arms PocketFighter 5 3,879 23-08-2016, 08:02 AM
Last Post: PocketFighter
