Need a wiring diagram for my car?!
Can someone get one for me? Need to know what wires do what for the door locks, the alarm, and he ignition barrel? Also if someone knows of some instructions for my original alarm that would be great, rep awarded as always Smile
What do you want to know about the alarm? and heres a link to wiring diagrams
http://306oc.co.uk/forum/thread-9993.htm...g+diagrams
Got an alarm i was planning on fitting, obviously i already have one but this came up cheap and its got a better range than the crappy rf remote i have now so might aswell, i wanted to turn the original one off so obviously i dont have 2 working against eachother.
306's negative door triggers?
Right having a few issues with this.
Basically i have figured out via proding and poking that earthing the orange wire shown below locks all the doors:
[Image: 20130725_174823_zpsdf94a0e2.jpg]
Awesome i hear you say, yes halfway to a working system but, now i cant get the doors to unlock via the wire i thought i also had to earth to make it unlock. But then i had a look at the wiring diagram again:
[Image: 2010-02-01_103118_Viper_350H_zps939fe51c.jpg]
Now if you divert your attention to the upper left of this diagram:
[Image: alarm_zps834304f2.png]
You will notice it says:
Green wire "- lock" "+ unlock output"
It then says,
Blue wire "+ lock" "-unlock output"
So does that mean the unlock wire needs a positive feed to unlock? Because the lock wire uses the negative/ground?
  Wiring diagram for heated seats bebic 0 2,962 28-04-2019, 07:30 PM
Last Post: bebic
  3 Plug ECU wiring diagram Uberderv 2 5,629 09-07-2017, 01:04 PM
Last Post: Uberderv
  D turbo ph2 fuse box diagram hilly5672 1 2,884 23-05-2016, 10:15 PM
Last Post: hilly5672
