Threads: 96
7
Car Model/Spec: 306 tractor
Given 0 thank(s) in 0 post(s)
Foobs or Scott did it Chris?
Fingers crossed its pennies to pass the MOT and you can get that big step closer to getting the new lump in
Threads: 591
54
Threads: 541
124
So today I decided that before I remove the original clutch and flywheel from the 2.2 I'd remove the crank pulley so I can do the cam belt and more importantly swap to my shiny lynx one. Anyway the gun wasn't man enough to undo it so I had to use the breaker bar. Sadly I couldn't find a decent locking point for the flywheel so used my ingenuity, enter stage left Mr and Mrs pry bar. One jammed wasn't enough so I had one wedged between the flywheel and the head and the other between the flywheel, the floor and my foot while stopping the engine falling over with my knee. Anyway don't try this at home kids as I thought I was gonna snap the pry bar but eventually it came undone.
Decided that I'd better check that the pulleys were the same and fortunately they are.
Next I decided that I'd have a bash at removing the swirl flaps, long story short its about a million bolts, my injector pipes didn't want to budge and I wasn't entirely confident that I could keep the timing of both cams with the carriers off so I gave up before removing the cam carriers. I then spent 10 mins fishing about with a torch and a very long cable tie trying to drop the tie down a swirl flap inlet tract while flipping the lever back and forth and eventually worked out the open position for the flaps. Gonna bolt through the lever to stop it moving.
One day I will find the enthusiasm to remove and clean the inlet manifold but that day isn't gonna be today and its not gonna be tomorrow either.
Also for those who didnt see the thread in the lounge I slightly reversed into yet another bollard the other day.
Threads: 591
54
surely the flaps are needed?
Threads: 541
124
(15-10-2013, 07:57 PM)Piggy Wrote: surely the flaps are needed?
Nah not really, they do increase the efficiency by shutting off 4 of the 8 inlet ports at low rpm/boost to increase the velocity of the intake charge and give better swirl thus better mix, cleaner burn and more power/economy but I don't reckon I drive that slowly often enough for it to be worth the mind f*ck of trying to control them opening and closing at the right times.
Threads: 541
124
Soooooo, its pay day and ive spent far too much on the car. About half the money for bits I need to get her through the MOT and half on shinys to make the 2.2 work.
Threads: 90
54
Chris the tensioner setup is seperate to the top rocker cover part, your safe to take it off, there easy to time up anyway....
Threads: 6
2
Car Model/Spec: Rover 214si
I am enjoying the crank locking tools.
Threads: 541
124
(18-10-2013, 11:55 AM)darrenjlobb Wrote: Chris the tensioner setup is seperate to the top rocker cover part, your safe to take it off, there easy to time up anyway.... Yeah its just that I didn't want to loosen off the cam belt tensioner as it was it was damp and i wasn't in the mood for counting cam belt teeth to make sure it times up correctly later. I may do it properly at some point.
(19-10-2013, 09:01 PM)tenwierdufos Wrote: I am enjoying the crank locking tools. Cheers mate, thought it was an inspired idea
Anyway I've been to wales today and been reminded of why I hate the welsh police but I've picked up a new interior. Any guesses what its out of?
I might see If it bolts in tomorrow depending on how hard its still trying to rain.
Threads: 591
54
what wrong with my old lovely "part worn" interior!?
Threads: 189
10
Car Model/Spec: E39 ACS 535i
Given 2 thank(s) in 2 post(s)
E36/46 half leather sports interior?
Threads: 541
124
@Piggy - LOL the interior you gave me was good (for the money) but I want something a bit different, a bit more comfortable and that goes a bit further back and sits lower down.
You can have the fronts back if these fit if you want (bring your welder when you pop over to pick them up lol).
(20-10-2013, 04:12 PM)Chris Wrote: E36/46 half leather sports interior? Damn you your right, E36
Threads: 6
2
This didn't take much guessing haha.
Threads: 189
10
The side bolsters and pattern of the fabric give it away. Coupe interior by any chance.
Threads: 541
124
(20-10-2013, 04:15 PM)Chris Wrote: The side bolsters and pattern of the fabric give it away. Coupe interior by any chance.
Dont remember mate.
Threads: 6
2
I think they need to go in my car, it would be much easier
Threads: 226
24
Car Model/Spec: A3 TDi
You think they might fit straight in?
Threads: 541
124
(20-10-2013, 04:15 PM)Chris Wrote: The side bolsters and pattern of the fabric give it away. Coupe interior by any chance. Turns out it was a coupe.
(20-10-2013, 05:12 PM)tenwierdufos Wrote: I think they need to go in my car, it would be much easier It would but much less awesome, you can have the rears if you want for a beer or 2
(20-10-2013, 05:35 PM)Tom Wrote: You think they might fit straight in? I was hoping that although the distance between the rails is narrower on the BMW seats (by about 40mm) the fact that the BMW has big holes for its mounts and the 306 mounts slide would mean I could get away with it but it doesnt look like I can. The BMW rails are also about 100mm longer.
That said I got the passenger one in on the nearside front bolt and they are sooooooooooo comfy, with the height all the way up and the headrest up it will touch the roof but with it down itll easily slide back far enough to touch the rear seats. Cant wait to see if i can actually get them fitted tomorrow.
Threads: 581
195
Given 81 thank(s) in 77 post(s)
look forward to seeing them fitted. IMO, the seats is the biggest let down of the 306 but then i think that might just be something that tall people suffer from!
Threads: 541
124
(20-10-2013, 06:12 PM)Niall Wrote: look forward to seeing them fitted. IMO, the seats is the biggest let down of the 306 but then i think that might just be something that tall people suffer from! I think part of the issue is the angle of the base as well as not going back far enough. These BMW seats although wont go any lower are a huge amount more adjustable and will give me a huge amount more front leg room, As I said above, theyll happily go back far enough to touch the rear seats so you cant do any better than that.
The only downside is they weigh an absolute fuckton they must be about twice as heavy as the 306 ones.
Threads: 581
195
Yeah thats what i found with the RX8 seats. Much more adjustability except bolsters
Mine are actually slightly higher than the 306 seats (will be changing that soon when i find time!) but because they are much more "bucket like", they are in a much better position for driving. Now i just need to bring the steering wheel towards me!
Threads: 541
124
Yeah im gonna have exactly the same issue with these, steering wheel too far away lol but this can be solved easily with becauseracecar dished wheel and a spacer or quick release.
Threads: 6
2
100mm longer, wow that is quite a lot! Talk about going back further...
Threads: 117
119
Those seats should be awesome, if you can make them fit lol.
Threads: 541
124
(21-10-2013, 05:34 AM)Poodle Wrote: Those seats should be awesome, if you can make them fit lol.
Shouldn't take alot of effort, just need to get some angle iron. I really need to get off my arse and do something with my day but thats not happening.
Threads: 541
124
Threads: 171
46
Car Model/Spec: Black 3dr Dturbo
Given 1 thank(s) in 1 post(s)
LOL@ the rear legroom! haha
Threads: 541
124
(21-10-2013, 07:10 PM)4WayDiablo Wrote: LOL@ the rear legroom! haha
The picture doesn't show it well but thats actually touching. That said some cars come like that out the factory.
Absolutely cant wait to get the drivers seat in and hopefully be comfortable.
Threads: 208
60
Given 5 thank(s) in 5 post(s)
So can you only get one bolt in then chris?
Threads: 202
58
Given 29 thank(s) in 28 post(s)
(21-10-2013, 07:46 PM)puglove Wrote: So can you only get one bolt in then chris?
But if you use an M24 bolt, instead of 4 M6 ones, 4x6=24, therefore it's 4x as strong and you only need one /dumdummaths
