XUD Inlet manifold studs
Right whats the deal with these, am i right in thinking they came on some xuds before or after they started using allen bolts? Or is it dependent on what car the engine was going into? Or do i just buy a set of stud and nuts of ebay in the right size?
I think it was the earlier ones that had allen bolts, might be wrong though, mine was studs but when the turbo went i got some allen bolts out of a scrap xud, much less hassle than the studs Smile
Blaze '6 and Blaze D-turbo!
I dont care about hassle, i want studs so my heavy hands can barry up the inlet manifold lol!
No doubt someone on here will have some, or any scrap yard most likely Smile
Mine has studs and nuts, engine is from a 1999 DT so maybe it was the earlier ones that had allen bolts?
Dont suppose you know what size they are? Might just buy a big bar and some nuts and cut them down myself. I think they are 1.25 thread pitch but not sure on width, i'd guess 6 or 8, they're not like the exhaust manifold studs :/
(21-07-2013, 11:45 AM)bigcheez2k3 Wrote: Mine has studs and nuts, engine is from a 1999 DT so maybe it was the earlier ones that had allen bolts?
Mines a 96 D8A block and i got allen bolts lol :/
13mm nuts, so M8?
Also, exhaust nuts, I think, are copper.
So M8x1.25 is the first guess! Anyone confirm that?
I dont think they copper, i always thought copper was really soft? Surely you'd tear the threads out if you put any kind of force into it?
Measured one of my bolts and i think they are an M8x1 or an M8 Fine thread whichever you want to call it. Its alot harder to find M8x1 stud than it is to find M8x1.25!
M8*1.25 is fine thread? Normal M8 would be 1.5
Thats what i thought but it seems there an even finer thread lol!
Anyone definately know what size they are? Really want to order some studs asap!
I might have missed it further up by why do u want studs over bolts?
[Image: av5ym8.jpg]
Im heavy handed and like to do them tight, not to mention im going to run some big boost so i want studs that i can tighten up more.
Fair enough.
[Image: av5ym8.jpg]
(21-07-2013, 06:56 PM)Tom Wrote: Im heavy handed and like to do them tight, not to mention im going to run some big boost so i want studs that i can tighten up more.
this, you can torque down studs properly while bolts can pull the thread out of the aluminium head if you do them up too tight. studs are ftmfw
Right I need to get a tap ordered up so can I have some confirmation please!? Thanks.
8x1.25 mate.
Thanks Tom.
Yeah, the *early* engines came with allen bolts, but you'll end up destroying the cylinder head when you do them up, it's the action of it tightening and twisting on the aluminium threads, it'll just pull the threads out the head and you're left with a f*cked head.
Just use studs and nuts.
  Exhaust and inlet manifold spacers and studs andyyy 1 2,449 15-03-2015, 01:51 AM
Last Post: zx_volcane
  inlet mani studs philpemberton94 9 5,254 13-08-2014, 01:40 PM
Last Post: Dave
  Inlet Manifold Gasket ally406 6 4,685 11-11-2013, 10:37 AM
Last Post: ally406
