Threads: 8
Car Model/Spec: PH2 1.9 D-Turbo
Given 0 thank(s) in 0 post(s)
So first trip to work in the Pug this morning and I gotta say it sounds like a Tractor at idle...... very loud and I don't know if I am imagining it but sounds like a belt could be loose? Anyone had a similar problem with theirs?
Threads: 208
60
Given 5 thank(s) in 5 post(s)
if you mean it sounds really clattery that standerd issue on an XUD. refinded isnt somthing the XUD understands.
also get you cat & silencers cut out then you can call it a tracter lol
Threads: 374
38
Car Model/Spec: GTI 6
the engine should/will sound like an old bus sound. none of this new eco-nonsense.
or familiar to an old transit. It will sound clattery. If you're unsure about belts. just whip the covers off, make sure everything is clear of the belts, start it up and just get a keen eye on the belt.
if it is loose, you 'should' see something wrong.
Threads: 91
83
Nah seriously, stock XUDs with an original exhaust aren't that bad, we're all just used to tuned ones running more timing with big pipes, they are dieselly, but no more so than most diesels of it's era... I mean, Transits of the same age make them sound like the smoothest creamiest lumps ever...
Sounds like you've probably got a failed tensioner, they rattle and clatter causing the engine to sound rough as bollocks...
(16-05-2016, 10:45 AM)Toms306 Wrote: Oh I don't care about the stripped threads lol, that's easily solved by hammering the bolt in.
Threads: 91
83
Errr, does yours have an aircon button... If so I think the part is about 70 quid, bit of a knob to fit... If its a non aircon its probablt about 30 quid and easy to fit...
Threads: 91
83
Yeah, go look under the hood when it's running and you'll probably see the tensioner flapping up and down...
