15-07-2013, 08:34 PM
Some scumbag threw a glass threw my drivers side window last night.... while i was driving the car. But anyways, whats to be done to put in another one? have a spare outside.
Window got smashed. How to replace?
15-07-2013, 08:52 PM
I had this...although it was a prat of an officer.
anyway... remove door card remove window seal around window edge remove sound deadening. hoover/remove all the broken glass from inside the door, loocate the window securing clip its white/cream and square and may still be on the dowel on the window mechanism slide in new window, about half way is easiest, then connect your window switch and put the locating dowel where the hole in the window is. pop the dowel through the hole in the window and put that square clip on and twist it. put window rubbers back on...right PITA and fit all back up. check the window works nice before putting door card back on etc! Wishes for more power...
15-07-2013, 08:59 PM
^^^ As above. Be aware that the cream securing clip can sometimes be green too!
![]() Member of the 99% warning or you're nothing club 2000 Moonstone 1.8 Meridian - Sold 2000 China 3dr XS - Dead 1998 Diablo 3dr XSI
15-07-2013, 09:07 PM
yeah it's not really that hard, crack on it's one of the easier jobs you'll do . .
15-07-2013, 11:16 PM
Window in
buuuut i cracked that green clip so now its extremely tight going up cause the clip slightly slides off the rail!! Anyways there should be a spare one of them outside aswell, window is up and secure for tommorow anyways, all i have to do is get up at 6 in the morning and do a days work now
15-07-2013, 11:21 PM
well done...im sure someone has one spare on here!
| Bonnet cable repair/replace | RetroPug | 6 | 3,585 |
02-02-2016, 09:19 PM Last Post: RetroPug |
| Master brake cylinder -replace or re-seal? | Beanie | 20 | 9,338 |
14-09-2015, 05:14 AM Last Post: Beanie |
| Replace 205 Roof Skin | Daniel306 | 0 | 1,589 |
27-12-2013, 05:28 PM Last Post: Daniel306 |
