14-07-2013, 09:07 PM
Whats best stuff to use to fit spoiler to car?
Spoiler fitting
14-07-2013, 09:40 PM
If its got screw holes and your boots got the holes you can get the screws from pug for about a quid each iirc
15-07-2013, 10:48 PM
I just bolted mine on, it came with the screws, but as said above there are pretty cheap from pug. I just put a blob of grease on the holes offered up the spoiler to the car, and then took the spoiler off and the grease left a mark where the holes needed to go, drilled the holes in the boot lid , and job done.
15-07-2013, 10:51 PM
It all depends if you have the holes in the glass as to if you can bolt it on. Tiger seal would be a better bet than drilling glass if you don't have the holes IMO.
![]() Member of the 99% warning or you're nothing club 2000 Moonstone 1.8 Meridian - Sold 2000 China 3dr XS - Dead 1998 Diablo 3dr XSI
16-07-2013, 08:04 PM
As above if it is a phase 3 one as the OP says then you drill the bootlid, iirc it is the earlier phase ones that go through the glass.
16-07-2013, 08:10 PM
(16-07-2013, 08:04 PM)titch Wrote: As above if it is a phase 3 one as the OP says then you drill the bootlid, iirc it is the earlier phase ones that go through the glass. Correct. But I dont like idea of drilking through my boot. So tigerseal arraived today
| Fitting Phase 3 Spoiler | philpemberton94 | 6 | 3,696 |
28-07-2014, 08:18 AM Last Post: philpemberton94 |
| gti spoiler fitting... | Piggy | 8 | 4,662 |
17-02-2014, 04:54 PM Last Post: Connor |
| Fitting a rear spoiler... (Pics inside) | silestanix | 15 | 18,304 |
08-04-2013, 05:04 PM Last Post: maxlee |
