Pulling left and right
Been out and about today and had an issue develop on the 6
Was fine for most of the day parked up and when i set off noticed Whenever i accelerate the car pulls to the right and when i lift off pulls left
Could it be a tracking problem or something more serious? I know the top engine mounts not great...
Sounds tracking.
Get it done professionally for an accurate result ThumbsUp
wishbones moving= p bush gone to meet its maker ??
check/replace and only then get the tracking done
I would likewise go with P-bushes. Had similar symptoms when mine separated from the housing. Tracking would cause problems in one direction, not both.
Seems to only have the issue when turning right or going straight, left is fine
Estimated cost of p bushes and best place to buy?
(15-07-2013, 07:24 PM)rocker8742 Wrote: Seems to only have the issue when turning right or going straight, left is fine
I'm having exact same issues at the mo, p-bushes are cheap (about£12) but you need a press to get them in. Check the bolts that hold the wishbone on by the p-bush as well as my bolt had sheared off completely creating even more wobble under load and braking.
Had them swapped over yesterday and apparently the captive nut had sheared off aswell
  Reasons for pulling to left? lolsteve 37 19,109 26-06-2014, 10:12 PM
Last Post: Jtrigga
  Pulling to the right Niall 47 32,323 14-11-2013, 06:39 PM
Last Post: Ican
