Td04 outlet to tmic
Does the td04 outlet fit straight onto the standard tmic pipe?
It does Smile
Team Doesn't own a 306
Yep, just make sure you've pointed it in the right direction.
as said yes it does along as you have clocked the turbo to be pointing in the right direction
thought so! cheers
Exclamation needed urgent, standard turbo to tmic pipe! Mattcheese31 12 9,193 30-09-2013, 10:55 AM
Last Post: Mattcheese31
  TD04 Outlet Size c.gerrard 3 3,389 17-09-2013, 04:17 PM
Last Post: c.gerrard
  td04 outlet to tmic scottbmxer 9 5,576 25-07-2013, 09:08 AM
Last Post: CJ_Derv
