Brake pedal spongy
So just got my sigma GTI Smile but slight problem with the brakes the pedal feels spongy but the brakes work fine. When the engine is off and you pump the pedal it's goes solid so I'm quite confused.
Bye Bye D-Turbo
When you pump up the brakes with the engine off, does the pedal creep much/atall if held on?
sounds like a nice fluid change is needed.
sort any air out and old fluid gets to feel horrid.
get some 5.1 in ya life! win1
The pedal doesn't creep it stays solidso I'm quite confused
Yeah was thinking that I don't think it's anything to major they work fine but the pedal just doesn't have a nice feel like the dt.
Bye Bye D-Turbo
5.1 can be got for a tenner.
a litre would probably do it...but grab two for future use.
best 1/2hr and 20quid you will spend. brakes not to be fooled with!
Was just thinking il need to bleed the abs pump won't I? I'm feel like a complete noob.
Bye Bye D-Turbo
Give it a good fluid change! Had exactly the same symptoms as this with mine, and a fluid change took it away
3 x Peugeot owner.
1996 106.
1996 306 D Turbo S.
1994 Mercedes Benz 320E.
1997 306 GLX.
(11-07-2013, 07:51 PM)Jtrigga Wrote: Was just thinking il need to bleed the abs pump won't I? I'm feel like a complete noob.
that will happen as you bleed each corner.
1.5litres with abs then I would say to allow
Thank you for the help everyone I read that you need to plug the car in to do the abs but that must of been poor information thanks again il leave you rep.
Bye Bye D-Turbo
You can plug the car into PP to do single person bleeding. Otherwise, as piggy says, any air in the system will be bled through regardless Smile
How do you bleed the abs pump then? Without pp (and with) ?!?
Oh I didn't see piggy's post above about the abs pump, just as usual then!
Bleeding the abs pump without PP you just bleed the brakes as normal. Remember to start furthest from the brake servo, back towards the nearest.
With PP, I do not know. When a warning light comes on I remove the bulb :p someone will be able to help you.
You dont need to bleed the ABS pump. The valves stay open constantly until the abs actually kicks in so its just like bleeding a system without ABS.
What grants saying is if your on your own, instead of having a friend help bleed, you can plug PP in to the car and it will modulate the pump to do the job of the person in the car. All you have to do is keep the master cylinder topped up and open the nipples until you get a steady flow of fluid.
  Hard Brake Pedal ct-hdi 5 3,635 04-01-2016, 06:57 PM
Last Post: ct-hdi
  SPONGY CLUTCH, heavenly 5 2,781 27-03-2015, 06:10 PM
Last Post: Niall
  solid brake pedal thebluepearl 8 6,069 02-12-2014, 08:32 PM
Last Post: jonas306
