306 GTI-6 Front struts and springs on a HDI?
I have a 306 HDI Y Reg, soon to have a stage 1 with a full straight through. The only thing I want to improve on the car is the suspension. It sounds a bit knocky so instead of replacing with standard parts is there any improvement fitting the GTI front struts and springs? and are there any fitment issues?
Cheers in advance
Jack
They will fit fine, however as the engine in the GTI6 is a fair bit heavier than the HDi engine, it will sit about 15-20mm higher if not more
If you have a merdian then yes it will be an improvment. Though i wouldnt put gti springs on as it will make the car sit higher than it currently is due to the lighter engine. IIRC
Oh f*ck off danny ffs
lmao learn 2 forum douchebag!
Yeah as said GTi6 shocks might be an improvement but the springs will raise your ride height 10mm at least.
It also might not cure your knocking depending on whats knocking.
Cheers for the reply's, I will fit the GTI6 shocks and then play with different springs. Are the rear shocks worth messing around with? I will be leaving it standard height..
If they need replacing.. i'd definitely recommend some gaz adjustables for the rear Smile
I put gti shocks and -40mm springs in my 1.9td lx and it sits sweet
93 106 xsi
98 306 1.9d
98 306 1.9td lx
01 306 2.0hdi
97 306 1.9td estate
96 306 dturbo
96 306 dturbo
we need a FAQ thread!!!
I fitted Hdi spax shocks and springs to my gti6 and it dropped the same as it did on a Hdi i was expecting a bigger drop but didn't happen Sad
  Front springs rest cap wanted Cho99er5000 0 2,185 01-10-2017, 05:52 PM
Last Post: Cho99er5000
  Gti6/VTS Front Shocks/Springs MY95 14 7,854 05-10-2016, 08:23 AM
Last Post: Toms306
  Xsara vts front shocks / springs?? Tc306 5 4,599 06-06-2016, 09:23 PM
Last Post: Tc306
