Identify these calipers
Had a head scratch moment earlier; i've got a set of calipers under the impression they're DT calipers (247mm?), so, i bought a set of discs and pads to match.
The pads are for a "206 HDi" which i assume are the same part number as the 306dt.
anyway, short of the long; the pads look too small and a slightly different shape; i know non-originals/oem can differ slightly, could this be it? or do i have the wrong caliper all together. I bought them so long ago it's past me.
[Image: wedcK26.jpg]
[Image: KMG4bfw.jpg]
[Image: aLbHDkE.jpg]
Rep etc x
They look the same as the ones on my HDI. They are the 266 disc type.
Ah.
Question is, will they fit behind 14'' steelies... hmm?
ECP part number 101545388
http://www.eurocarparts.com/ecp/c/Peugeo...72d&000036
(09-07-2013, 02:40 PM)ginge191 Wrote: Ah.
I couldn't tell you sorry as I wouldn't know without trying some on mine.
hmm ok, i'll take a pad with me and match it up to theres ThumbsUp
can anyone confirm these as HDi brakes?
Forgot to say my girlfriends got a 206 hdi Dturbo and her pads and calipers aren't the same as mine but her discs are 266mm.
Don't forget on all 306 brakes other than 283s, there was at least two different manafacturers all with slightly varying pad designs. Could be you have bendix pads there
(09-07-2013, 03:01 PM)Niall Wrote: Don't forget on all 306 brakes other than 283s, there was at least two different manafacturers all with slightly varying pad designs. Could be you have bendix pads there
hmm i'm not sure; because even the disc doesnt sit all the way in the caliper; only about 3/4 into the caliper
Can't see the pictures, but if they're 266s, they fit under 14s, specifically they'll fit under your 14s
ideal.
and yes, they are HDi 266's. Just got a new set of discs and pads now to match ThumbsUp cheeky upgrade for the 205 it seems!
  Identify these front brakes.. Dazecoop 14 8,176 21-12-2015, 04:24 PM
Last Post: Elfyno
  identify these calipers.. eskimogod 4 3,343 11-10-2014, 08:05 PM
Last Post: welshpug
  Can anyone help identify my wheels please chugapug 9 5,406 24-07-2013, 11:44 PM
Last Post: juz22
