White smoke and high temp
Peugeot 306 hdi stage 2
So I've just come back from holiday and took me car out for a drive I let it warm up and every thing seemed fine then I noticed the temp was close to 90 once it hit 90 every time I pulled away there was a lot of white smoke I've check the water and oil lvl and they have not moved also done a pressure check the pipe was hot and was a bit hard to push in any one have any ideas?
90 sounds fine for a hot day...
white smoke from exhaust?
Yeah white smoke from exhaust
odd. very odd.
water not gone down?
Water lvl is the same I've just double check. there is no white smoke till it hits 90 then every time I pull away there is loads of white smoke then it clears till I stop again. With in 4mile drive the temp was about 80.
Sounds like my car lol turned out my valve stem seals had gone....but 90 i think is normal to be honest mine sits beetween 70/90
(msg sent from hell)
never goes above 90 degrees?
funny noises? loss in power? is it just when you pull away or when on boost?!
It will only just go above 90 but once it hits 90 the white smoke starts its only when pulling away. No noises or loss of power at all.
Its not normal for hdis to run at 90 guys, about 75 is the norm. Sounds like hg to me, why else the rise in coolant temps.
ah righto...well 90 is normal for xud...
agree then with Poodle. sorry
Ahh I really hope it's not are they hard to do? should I leave it for a while and see if I start losing water or check the thermostat to see if its working?
Are you sure its white smoke cus burning oil smoke is very very light blue if its only burning alittle i know this cus my valve seals went on mine and oil was seeping in slowly not enuff to notice over a week but a puff of smoke on start up and pull off but nothing after yes it may well be a hg but i would monitor your levels for a few days and temp see what happens never think the worst i thought my hg went my heart sunk but like i said changed my valve seals without removing the head or putting rope down the hole lol i have the correct tool for doing valve seals without removing the head...just observe first mate never fear the worst...
Its not too bad a job if you give yourself plenty of time. If your stat was the problem, then the top rad hose wouldnt be getting hot.
If it was the valve seals why would the temp be really high?
  white smoke from starter motor apples76 12 6,777 17-07-2017, 05:05 AM
  Intake temp and Exhaust temp sensors? JTaylor2005 5 4,865 26-12-2014, 02:04 PM
Last Post: JTaylor2005
  White smoke LewisG 8 4,737 22-05-2014, 06:18 PM
Last Post: LewisG
