Wanted: rear beam mounts set
i would like a buggered set of rear beam mounts,
full set of 4 please
all i ask is the mounting bolts are good and not broken
FREE if possible or exchange for homebrew Smile
can collect at Pugfest
thanks guys
(04-07-2013, 12:17 PM)cully Wrote: i would like a buggered set of rear beam mounts,
thanks guys
I think I have 2. I do have full set of I can find them
Ill have 4 for you when I swap my beams over. Will take some more of that homebrew off you
(04-07-2013, 01:49 PM)Connor Wrote: Ill have 4 for you when I swap my beams over. Will take some more of that homebrew off you
Yeah good point the. I have 4 good ones sat on my car. I'll be changing them over in a couple weeks when I let my beam and fit my solid ones
i dont want good rubber ones lol
i will be turning them into solid mounts
so i will be removing all the rubber Wink
Ok. Ill find the other 2 mounts or for you then tomorrow. Will pm you
  Wanted: Rear Beam (Disc or drum) Eeyore 10 6,898 05-04-2016, 08:00 AM
  Wanted: solid rear beam mounts af1 0 1,697 31-05-2015, 06:34 PM
Last Post: af1
  Drum rear beam Matt 0 1,716 26-05-2015, 10:08 AM
Last Post: Matt
