CHEAP: GTi6 inlet - Rallye Aux set up - 266mm calipers
I need money for more shinys so have stuff for sale cheap, needs to be gone. Cant post as I cant walk or drive to go to the post office.
- GTi6 inlet and throttle body with all sensors, part polished outside, bunged resonator fitted with XSI fuel rail and injectors so ready to fit £25 collected
- Rallye aux belt set up (to remove air con from your 6) all used parts but no funny noises, belt, both pulleys and all the bolts. £10 Collected
- Bike bodies, forget what they are off, possibly a ZX12 but they are 46mm across the throttle plate. Came spaced correct for a 6 manifold as standard and come with 4 joiners and sufficient decent clamps to bolt the whole lot together onto a cut down 6 manifold. Has its original TPS and a set of 4 individual 60mm cone filters one for each body. Also comes with sensors, rail, GTi6 injectors, adjustable fuel pressure regulator and possibly some other bits. Throttle cable mount drilled to accept a standard GTi6 cable. £100 Provisionally sold
- HDi 266mm calipers £10
bloody el them TBs are cheap....if only I had a gti!!
F*cksake dum you do this when im skint?!
Pictures of the bodies chris?
Ill find one in a bit, vaughn has dibbsed them though
First refusal Chris?
After vaughan anyway...
(03-07-2013, 07:50 PM)rocker8742 Wrote: First refusal Chris?
Yeah, why not, vaughn asked 3 mins before you did so its all fair.
Bugger new i should of put dibs in that first post lol
Just realised i don't have any more pictures of them than these. I also haven't written down anywhere what they are off. They were a big super bike type thing.
[Image: attachment.php?thumbnail=3130]
[Image: attachment.php?thumbnail=3131]
[Image: attachment.php?thumbnail=3132]
[Image: attachment.php?thumbnail=3133]
Deposit taken from vaughn for the bike bodies.
Rest still for sale Smile
What condition are calipers in m8?
Scott
They were working when they came off the car and have been in my workshop for a month or 2. IIRC they are the original cab ones (but I forget whats gone where as I had 3 pairs at 1 point) so 14 years old and 125k
Are bleed nipples free on the calipers? Any chance of a pic? Are you going to pugfest/fcs? To Save on postage
Rallye set up, mine!
(05-07-2013, 09:05 PM)Chris_90 Wrote: Are bleed nipples free on the calipers? Any chance of a pic? Are you going to pugfest/fcs? To Save on postage
Don't know about the nipples, haven't tried them. As described above I'M NOT DELIVERING OR POSTING BECAUSE I CURRENTLY CANNOT WALK OR DRIVE!!!!
(05-07-2013, 09:07 PM)Matt Wrote: Rallye set up, mine!
Cool babe, when you coming for it.
OK! SORRY DIDN'T SEE THAT BIT!!
Thanks any way
Hold it for me until next month? Should be back over then sometime
Cool babe
  GTi6 Inlet and Exhaust Manifolds reese 2 3,204 17-11-2019, 04:47 PM
Last Post: reese
  GTi6 Calipers Alan_M 1 2,318 27-10-2019, 08:42 PM
Last Post: Alan_M
  GTi-6/Rallye front calipers mattsrallye 2 3,214 08-01-2019, 04:58 PM
Last Post: wainwrightj
