02-07-2013, 08:39 PM
Hi. Just done a clutch change on father-in-law's 206 1.4 petrol. Fairly straight forward apart from the off-side drive shaft being seized in the support bearing.
Anyway, I didn't bother marking the pressure plate to flywheel relationship as it's a new clutch, but on close inspection I see there's a "dowel" fitted on the pressure plate near one of the fixing bolts. Is it critical where this goes or is it purely to balance the pressure plate ? My concern is that it's a trigger for a sensor, although the flywheel sensor doesn't appear to "look" at it, and there doesn't appear to be anything else.
Going to bolt it back up tomorrow so hoping someone can help.
Thanks
Thanks
