GTI nissens RAD
GTI nissens RAD
So iv got a nissens rad from a ph3 gti6 now the bottom left connection is different ...... now is this because it different between ph2 & 3 or am I missing a reducer or something?
Pretty sure phase 2&3 are different. Sure you could bodge it though Smile
The fitting is different. PH3 has a metal ring with a securing clip, PH2 and 1 has a 2 plastic clips on the hose. Easy enough to change the hose, its just clipped to the back of the block Smile
They wont fit cross phases.
(25-06-2013, 07:36 PM)Grant Wrote: The fitting is different. PH3 has a metal ring with a securing clip, PH2 and 1 has a 2 plastic clips on the hose. Easy enough to change the hose, its just clipped to the back of the block Smile
The hose or the rad?
And Peugeot are wankers!! why the f*ck change something stupid like that
You said it, they're wankers.
If you have a PH2 rad, then fir the PH2 hose. If you have a PH3 rad then fir the PH3 hose. The hoses will fit cross phases, but the rads will not, unless you change the hose. It clips on the lower side of the drivers chasis leg round to the rear of the block.
had the same problem fitting my replacment rad
old rad had a plastic clipped bottom hose
newer rad had a metle ended wire clip bottom hose
lucky enough i got the bottom hose with the replacement rad
changed the hose and the rad to match
AAhh what a bugger im not going to get that done tomorrow night then :/
think the metal bottom hose is a pug part too
part number 1351 Z3 but do check!
Can get one of my mates spare 6, but just gotta get over there
whats the engine block hose clip like?
Later metal ended push fit hose (suitable for Nissens radiators) - 1351ZV AND 1351Z3
Older plastic wing fitting - 1351X9
Cully is correct
http://www.pugaddicts.co.uk/2012/11/peug...tting.html
[Image: sigjpg.jpg]
Serious.
Just a normal crimp clip. One you squeeze with pliers to slacken then it springs back when you let go. Same as top rad hose Smile
Ooohh that should be fun around the back of the block lol
easy! acsses is good if you remove the drivers wheel
end of the pipe is right in front just above the waterpump Wink
Ah that makes me feel a little better as its currently sat like this ready to recive its new shafts.
Attached Files Thumbnail(s)
why the bloody hell did pug have to make it so difficult in the first place? !
would a jubilee clip have been so difficult! ?
Any opportunity to photo whore :p
138 BHP XSI
(26-06-2013, 06:44 AM)Piggy Wrote: why the bloody hell did pug have to make it so difficult in the first place? !
Exactly or even one of those spring clamps they use EVERY WHERE eles on the cooling system.
/peugeotlogic
stop moaning like a bitch!
it wouldnt be fun if it were that easy
/Ford-Vauxhall assembly
If i dont moan on here i wont be able to post anything??? lmao
MTFU its not hard. Undo 3 clips on the chassis leg, pinch a clip with some pliers. Reverse the procedure for refitting the hose. Radiator, well youve got it off so your probably clever enough to put it back on
:p
pinch a clip with pliers?! wish it was that simple!!!
It was last time I did it Wink
IF you can even get a set of pliers in there any sence
propper squeeze tool FTW!
