Group Buy | ARP Head Studs for XUD *Order going in this Friday 8th Nov
#31
(02-10-2013, 08:34 AM)martyn92 Wrote: Also tempted. These can obviously be used more than once? And how do you fit these compared to standard?
Yes you can re-use the headbolts
They fit the same as normal headstuds, but you wind the studs into the block first, drop the head on, then put orignal spacers, arp washers and nuts on the studs to torque it down.
(02-10-2013, 10:56 AM)jammapic Wrote: If they are the same, count me in...
JP
Someone must have a hdi headbolt lying around?
I think ive a hdi studs somewere but im not sure, what lenght/thread are the xud ones, and I'll see if I have.
(02-10-2013, 01:09 PM)ConorTRG Wrote: I think ive a hdi studs somewere but im not sure, what lenght/thread are the xud ones, and I'll see if I have.
Dude its all on the first page, 145-148mm m12x1.25
yes 147-150mm for xud bolts according to haynes
Is it possible to fit these without taking the head off. While its in the car timed up if replaced one at a time?
TD04 11mm Sedan, now 2.1 vnt
Provence Dturbo Dead
Blaze 1.6 Dead
(05-10-2013, 05:13 PM)HDIkyle Wrote: Is it possible to fit these without taking the head off. While its in the car timed up if replaced one at a time?
Thats how I did mine, and how the boys in america do it. I did a search of google before I did it and seems legit
Yeah perfectly fine to do that Smile
Just whipped one off, i make that 145mm:
Head is E14, and not sure how bolt size is measured, but this is 10mm diameter. Thread is 1.25.
If that's all the same i'll have a set too. Big Grin
can you measure from under the washer to tip?
this is the diagram for xud from haynes
[Image: DSC_3804_zpsf16841ec.jpg]
~128mm...
I can whip a nut off mine tomorrow and measure how much thread is on the top of the stud
You'll need another 30mm is sticking out the top, will this foul anything?
Not front side, couldnt say about the back as one engines in the car and the other doesmt have anything on the block... Cant see 30mm being a problem though.
Will see if I cn put the spare engine together a bit tomoz and make sure.
Head's back on and there seems to be tons of spare clearance. BUT, having rechecked my blurry-eyed measurements from last night, i'm going to say the thread is x1.5mm... Tried to match it to a wheel bolt and it won't sit right... Sad
xud is m12 x 1.5
That's alright then, sorry was going on what Dan and Tom have said, it's the only info i could find at short notice.
Definitely put me down for a set then!
Can we get a list going again please?
If you guys like can leave it another 4 weeks if it helps
Ooo! Do we have 4?
1. Londondan86
2.
HDi Cabby Project Click
Please don't tell anyone I spent £200 on some bolts.
1. Londondan86
2. Ally406
'95 Peugeot 405 GLX with XU10J4RS and ITB's
'97 Peugeot 406 1.9TD with TD04
'05 RenaultSport 182 Cup
So we reckon they will fit a hdi then? Count me in....
JP
I still need to check thread length, will sort that out this morning
Looks like they'll need spacers for hdi I'm afraid
There is hardly any spare thread on top of the stud - after nut and washer we've got something like 8mm left.
By my calculations based on thread length of hdi bolt being 128mm you'd need spacer of about 18-20mm to make them work
Did you get my PM?
1. Londondan86
2. Ally406
3. Frosty
I'm pretty sure the hdi bolts are m10 too, whereas these are m12, couldn't find my calipers to confirm though. Its looking a bit doubtful tbh, thanks though.
Bugger.
JP
JP please do shout if you end up doing something similar for the hdi ones.
Surely hdi same bolt thread no? M10 seems to skinny
(07-10-2013, 03:09 PM)Poodle Wrote: JP please do shout if you end up doing something similar for the hdi ones.
How many people do you think we can get onboard? I can probably get a good price and order like 10 sets and sell them on the No Smoke No Poke shop for you all....
JP
JP
I suspect there'll be a few interested in the next six months or so, but then again how often do people follow through with projects... I can think of two people that would almost certainly be interested, but i'll leave them to chime in for themselves.
OK... let's see if we can easily make these XUD ones fit a HDi. If not, I'll look to order a few sets...
JP
  **wanted** arp head studs dr_jekyll 18 4,634 09-10-2017, 07:52 AM
Last Post: dr_jekyll
  FOR SALE: SOLD - £170 - XUD ARP Head Studs silverzx 3 1,528 06-11-2015, 11:59 AM
Last Post: silverzx
  FOR SALE: ARP head bolts/studs Piggy 8 2,185 07-07-2015, 01:18 PM
Last Post: Piggy
