Threads: 17
Car Model/Spec: ph2 306 1.4 3 door
Given 0 thank(s) in 0 post(s)
Hi, i was hoping someone could help me with my problem. When im just about to come to a complete stop when braking my battery light will flicker. It doesnt happen everytime. I think my revs are dropping to low but the car never cuts out on me. Any help would be appreciated. Cheers.
Threads: 164
25
Car Model/Spec: Gti6
Given 4 thank(s) in 4 post(s)
Checked the alternators charging right? Stick a multimeter on the battery should be about 14v with the engine on
Threads: 9
1
Car Model/Spec: P3 diablo 1.4 impreza wrx sti
I had a similar fault, turned out to be the earth wire on the battery wire loom thingymajig
Threads: 591
54
does sound like a bad connection somewhere.
Inspect the live to the alternator and your engine earths.
Earth by the GOOOO pedal too can be dodgy and that helps the dash stay bright!
Threads: 17
Thanks for the replys. Iv had a proper chance to look at tge dash when braking and i got it wrong. Its the oil light and stop light flickering slightly. Usually when braking to a stop and going down to second gear. Doesnt do ut when i stop out of gear. Could it be pump? Thanks.
