Wheel bearing noise after lowering
Iv just put a already lowerd rear beam on my car and noticed a wheel bearing noise only when goin round left bends and noisier when goin faster iv also lowerd the front I can't tell if its front or rear would it mean it was n/s or o/s if it only dose it on left bends
Id check if anything is rubbing first. Then I would check the rear wheel bearings. Only on left hand bends also suggests something on the o/s as that's where all the weight will go when going left
Ok cheers I did change the n/s rear bearing as it fell apart when I was changing over the beams maybe the o/s is gone aswell then
  Rear Disk Wheel Bearing daveylennon93 21 16,231 06-03-2017, 11:24 AM
Last Post: dt_
  Rear wheel bearing HDI? MY95 9 5,686 24-04-2016, 04:42 PM
  HDI rear wheel bearing part no? Wolverine1091 3 2,767 12-03-2014, 10:58 AM
Last Post: Wolverine1091
