Head change- do the studs need replacing?
As title really, just ordering parts for the car and just wondering if the studs need changing or not?
Stage 2 XUD Sedan
if you mean headbolts....defo
You mean the studs for the turbo manifold?
FAIL!
Yes I meant teh headbolts, wishful thinking I was getting studs but not on my budget Sad
Also does anyone know the thickness of the head gasket I should be getting? It's not for a skimmed head or anything.
Stage 2 XUD Sedan
I've never changed the head bolts when I've done a head change ...
Edit.
I always go for a 3 notch good quality MLS gasket
Team Doesn't own a 306
i went for 3 notch when i got mine. i got all victor reinz bits. head set, head gasket and head bolts for £74
Where did you get that from pal? Ill be dropping my head ff for skimming to prow so need to source a good gasket
I got the bits from a local car parts place. Your best bet is to phone around to see if anyone can get victor reinz bits
headbolts are like 12-16quid a set...not much to pay for the assurance
measure piston protrusion to check the gasket thickness, I think the last one I saw ended up being a 2 notch..
And for the money you may as well do the headbolts.
headbolts are stretch, you can measure them and see if they are still within tolerance. I've reused them before, not snapped one in the block yet!
head gasket thickness, just use whatever, really doesn't make much odds as they're very very close.
3 notch gasket, new bolts, can re use, but wats the point for 15 quid, altho if ur planning on raping the crap out of it, then uprate Wink
Just went to order head gasket, head bolts, rocker gasket, cambelt kit and some glowies for £147 from Eurocarparts but the f*cking card isn't working. So I'll try again tomorrow.
It's another £30odd for the head so it's making a costly mistake having this cambelt snap but it should be a good engine after this (until the rods make an exit).
Cheers for the help guys!
Stage 2 XUD Sedan
Use carparts4less cheaper than euro mate Smile
I've just checked and the parts I'm ordering are the same price. Aren't they the same company anyway?
Stage 2 XUD Sedan
Fair enough thought it mite be worth a mention
They are but think car parts for less come straight from warehouse to you usually a little cheaper
Managed to find a £15 off voucher code so managed to get the lot for £133 which is pretty fair.
Stage 2 XUD Sedan
Exclamation Read only???? Also head studs question ekjdm14 1 2,898 28-12-2021, 09:07 AM
Last Post: Mighty306
  Head head head studs ??? Yungpug 1 2,802 11-09-2017, 12:31 PM
Last Post: Chris_90
  XUD9 head gasket change video unclebeast 27 16,359 20-05-2016, 06:25 PM
Last Post: unclebeast
