TD04L Inlet Size
Is it 49mm? I know its smaller then T25 but I can't remember the TD04 and don't think a pair of calipers will fit down there very well!
I want to get some air filter piping sorted and need to know!
Thanks whoever! Tongue Blush
51mm I think I measured mine at.
Hmm, maybe I've confused myself. Tongue
Thought T25 was 51mm and TD04 < 50. Perhaps T25 is more like 54mm and TD04 51mm as you say.
Just get a 2" reducer for it, will tighten down with a clamp anyway
Mine is 55mm :-)
[Image: 65613_10200761612710317_1548698655_n_zps68c27004.jpg]
CONVOI EXCEPTIONNEL
(15-06-2013, 01:58 PM)martyn92 Wrote: Mine is 55mm :-)
Huh
I'll just try ram some callipers down there... lol.
The standard T2 intake pipe will just fit with a little persuasion.
(16-06-2013, 12:37 PM)Jonny81191 Wrote: The standard T2 intake pipe will just fit with a little persuasion.
Ok well pretty sure thats 49mm but can check, I'll figure it out. Smile
Run the BIGGEST pipe you physically can to it if your not running it open filter, the inlet pipe will restrict the turbo more than anything else on the entire induction / boost system, 30cm of pipe of the same size as the turbo inlet will be hugely restrictive, granted theres is shag all room down the back of an xud to run anything much bigger, hence most get left open, but its well worth trying!
(16-06-2013, 02:06 PM)darrenjlobb Wrote: Run the BIGGEST pipe you physically can to it if your not running it open filter, the inlet pipe will restrict the turbo more than anything else on the entire induction / boost system, 30cm of pipe of the same size as the turbo inlet will be hugely restrictive, granted theres is shag all room down the back of an xud to run anything much bigger, hence most get left open, but its well worth trying!
Hmm, can't see anything bigger then 2.5" flexi fitting where I want to run it..
  205 2.1 td 8s td04l-15t niciou 9 6,989 12-06-2016, 03:08 PM
Last Post: HDIkyle
  Top mount intercooler bolt size/ timing hole size LewisG306 2 3,081 13-07-2014, 10:44 AM
Last Post: LewisG306
  turbo upgrade td04l ingham66 uk 6 5,149 24-03-2013, 01:36 PM
Last Post: bigcheez2k3
