Threads: 87
48
Car Model/Spec: Rouge vallelunga 5 door Dturbo
Given 74 thank(s) in 70 post(s)
http://www.ebay.co.uk/itm/Peugeot-306-1 ... 2065wt_952
looks a bit cheap to me but i thought Delphi were ok, anyone have any experience to share? . .. . .
need to change my rear mount but considering doing both wishbones at that price if they're ok .
cheers guys and gals, Matt.
Threads: 0
Given 0 thank(s) in 0 post(s)
Delphi stuff is ok sometime get ball joints at work seem to be ok. Only last about 15k!!!
I am here: http://maps.google.com/maps?ll=54.071531,-2.865506
Threads: 581
195
Delphi stuff is good. Surprised that's so cheap!
Threads: 42
0
Car Model/Spec: 306 XRDT
Watch out for the ball joint size...
Threads: 171
46
Car Model/Spec: Black 3dr Dturbo
Given 1 thank(s) in 1 post(s)
D@wson Wrote:Watch out for the ball joint size... Definatly! Mine were too small and destroyed my hub good thing i got a new one
Threads: 87
48
D@wson Wrote:Watch out for the ball joint size... yeah i'm a 16mm kid . . . . . .found that out changing my balljoints recently .
Threads: 374
38
Car Model/Spec: GTI 6
Mattcheese31 Wrote:D@wson Wrote:Watch out for the ball joint size... yeah i'm a 16mm kid . . . . . .found that out changing my balljoints recently .
are they the same through phases, or through engine spec?
Threads: 87
48
[/quote]
are they the same through phases, or through engine spec?[/quote]
no and no . .
Threads: 27
20
S16's are 18 I know that much
Threads: 374
38
no and no . . [/quote]
how useful :think:
Threads: 87
48
ginge191 Wrote:Mattcheese31 Wrote:
are they the same through phases, or through engine spec? no and no . . [/quote]
how useful :think:[/quote]
you asked and i told . . . . . . . you want fcuking blood or what? . . . .
Threads: 34
8
Given 8 thank(s) in 8 post(s)
Thats for manual steering, not PAS mind, not sure if they are different, think they are though as they always seem to ask..
Threads: 581
195
Ball joints are different depending on pas or non pas. Also different depending on age. If its a ph3, you can practically guarantee it will be a 18mm ball joint but if it's 1 or 2, you will have to measure yours!
