Threads: 143
10
Car Model/Spec: Ph3 XUD
I have a beam in the garden and I want to check it for camber, would it be as simple as bolting wheels on it to look? Got a couple bare alloys I can attach.
Normally you'd just look at it in relation to the car.
Threads: 198
135
If the beam's off the car just get a good hold of one end and rattle it about looking for play mate, if the bearings move freely enough and no untoward play it'll be fine
Threads: 151
14
Car Model/Spec: 306 D-turbo
you cant check them like that they need to have weight on not sure if you can check them off car
Team Doesn't own a 306
Threads: 198
135
Er, how can you not check them like that? If a bearing has play, it has play. You can check anything with the right leverage and effort.
Threads: 151
14
I've always checked them on the car never off that's why I said I was unsure if you could or not but turns out you can
Threads: 465
114
Car Model/Spec: Vauxhall
put the wheel on the beam axle
upend the beam
stand on the inside of the wheel
grab beam tube and try to move it feel for movment within the tube bearings
Threads: 122
9
Car Model/Spec: Kingfisher Ph1 Dturbo S
There will too much tension from the TBs to feel off the car properly. If u look at the inner seal if it looks perished etc chances are corrosion will have f*cked bearings
Threads: 198
135
Nothing to do with tension on the torsion bars. If the bearings are f*cked you'll be able to see movement of the trailing arm. Trust me, i've seen it on beams off cars.
Threads: 58
3
Car Model/Spec: Loads
The only thing you can do is check the the seal to the trailing arm is a uniform gap all the way around, whent he bearings fail you'll see the arm at a angle to the tube, mind this is only a check and even beams that appear OK are quite often scrap when stripped done
