29-05-2013, 04:17 PM
SOOOOOOOOOOOOO any one got any idea where the earths on a 306 for the dash area other than the one behind the pedals?
Earth/ground points
29-05-2013, 07:08 PM
Fairly sure my phs1 s16 had one behind the panel under the drivers side dash, kind of too the right of the peddles
Passenger side footwell on the Left hand side big ass bolt all you got to do is scrape some paint off if there is any just pull the carpet back a little
30-05-2013, 12:41 AM
had a thought earlier, have you checked the big plug in the bulkhead on the drivers side? it has all the electronics from the engine to the dials/gauges
'09 Mercedes E320cdi wagon '99 306 gti6
30-05-2013, 06:42 AM
(29-05-2013, 07:08 PM)swampy Wrote: Fairly sure my phs1 s16 had one behind the panel under the drivers side dash, kind of too the right of the peddles Ill check that out later cheers (30-05-2013, 12:41 AM)ozonehostile Wrote: had a thought earlier, have you checked the big plug in the bulkhead on the drivers side? it has all the electronics from the engine to the dials/gauges Good point zak. Im going on the theory its an earth fault atm. I will take that plug out next.
30-05-2013, 10:59 AM
Do the speakers have an earth point?
30-05-2013, 04:40 PM
| Earth locations | pug306driver | 2 | 3,927 |
22-01-2022, 04:19 PM Last Post: pug306driver |
Gearbox earth connection part FIXED | Welshy_Pete | 7 | 6,030 |
22-05-2016, 06:29 PM Last Post: P-Courty |
| l/h/side earth point | pug306driver | 2 | 2,810 |
15-02-2016, 06:16 PM Last Post: pug306driver |
