Custom shaft help
Custom shaft help
Hi all I'm starting a v6 conversion in the next week or two and I need help with the driveshafts as the v6 ones r too long and the standard shafts don't fit the bigger hubs and a like so they need shortening can anyone help me out any advise be gd just want to know how can I shorten the shaft without custom shafts as tight on budget I would cut and weld but not shore ove strength and balancing so rather ask first thanks
used to be a place called m.a.n transmissions, they used to do custom shafts. ?
Ok brilliant ill look it up
