Boost leak
Hi guys got a dturbo with a t25 turbo witch has decided to spring a leak somewhere in the system. Can't find any crack in piping on top of engine but the air escaping noise sounds like its coming from where the turbo is located or in that general area any ideas on easiest way to locate and fix the problem? Cheers guys
If you can't visually see any holes, i'd suggest re clamping the pipe connecting to the turbo itself - could have become oily and slips slightly at a certain pressure
Yeah will jack the car up and have a look around see if anything has come loose cheers mate
you running a front mount or top mount intercooler?
Running a top mount at the moment but putting a front mount on start of next month
  boost leak ? Motatalk 3 2,997 19-06-2015, 07:46 AM
Last Post: Dave
  Boost leak... philpemberton94 6 5,002 13-06-2014, 10:31 AM
Last Post: toseland
  boost leak? willJspears 11 6,776 02-02-2014, 05:22 PM
Last Post: willJspears
