Harnesses - where has everyone mounted them?
As above, will be fitting my harnesses to my standard seats this week*
Where has everyone secured them down to? I'm more talking about the lap part?
*standard seats are only temporary until I can afford buckets
I know the dangers so please can we not send this thread that way.
Thanks
306 HDI, soon to be XUD
mate thats really dangeous!
I knew that was coming:L
I know where I'm putting them now though Smile
Oh god Doh
Dec get harness with the eye bolt style fitment as if you get the quick release ones your ll have to change your mounting points to eyelets. So first lap one use the original bit on the outer edge, , you'll have to space it out abit with washers so it does'nt sit flush and you can adjust it.
Then the tricky did as the inter mount is original on the seat its seat so you'll have to drill though just behind the center of the car and weld a plate one side with a screw thread then screw a bolt in which will attach to the harness.
I was very lucky when I brought my base mounts as they were mounts welded on to the mounts already so didn't need to bother with the above.the last bit seems abit of a piss around but when you do get bucket you'll be fully prepared.
[Image: Cn91r40h.jpg]
  fitting OMP harnesses declantg 6 4,477 22-11-2012, 09:47 AM
Last Post: puglove
Smile OMP Harnesses declantg 10 5,123 28-10-2012, 02:10 PM
Last Post: puglove
