Worth getting a gt15 turbo?
I currently have a t2, someone I know is selling a gt15
I know there both standard fitment turbos, but is the gt 15 better than a t2 in any way. Only ask as I'm gonna have the turbo off in next few days for the hg change
Unless your T2 is dead, then not really.
GT2052s DTurbo
OEM+ HDI Estate
Project thread
not really mate . . . .T2 spools later but carries on giving much higher up . .Smile
GT15 has some nice low down, pulling power, as far as BHP goes, it's outta puff top end.
A nice little turbo, and for the fun factor id swap it for the T2. ThumbsUp
As far as I know it's fine boosts well just a bit laggy with the fmic
Is there any way of making the t2 spool a bit quicker
Ginge bums the GT15 fyi though, apparently where he lives you can't get over speeds of 50mph . . . .Wink
I have a t2 on mine and a friend has a gt15 on his, gt15 spools up really good but as said above it runs out of puff top end, i wouldnt bother really if your t2 is in working order! Smile
Blaze '6 and Blaze D-turbo!
(19-05-2013, 06:26 PM)Mattcheese31 Wrote: Ginge bums the GT15 fyi though, apparently where he lives you can't get over speeds of 50mph . . . .Wink
seeing as i run a T2 now and have ran a K14 and a K03 in the past, i can't say i bum the gt15, but i know i loove the epic low spoolers. Angel
ahhh was it a K03 on the Sigma then? . . . .i knew it was something GAF . .lol x
Gt15 good for 130bhp?
That's sort of what im aiming for. Nothing to drastic just a reliable torquey DT
T2 is laggy? Really? :/
(19-05-2013, 06:48 PM)Jimbo Wrote: Gt15 good for 130bhp?
I'd say so - would be "pushing" the limit, but achieveable. Keep sensible EGT's and pressures, you should be ok.
If you want that power bracket comfortably, keep the T2
(19-05-2013, 06:50 PM)Tom Wrote: T2 is laggy? Really? :/
You don't have a front mount do you?it was ok before but takes it time now fmic is on
hahaha! lol
yeh, that was when i was living on the isle of wight, i'm now onto bigger and better things... he says Doh
sure you don't have a boost leak mate? . . . . most people report no noticeable difference after fitting fmic . . .Smile
Sounds like you have a boost leak tbh. Unless your fmic is MASSIVE. Shouldnt take much longer to fill the system atall.
If your really going through all the effort of changing the turbo, get a newer more modern turbo?
Look at GT17/GT20, best of both worlds
Peugeot 206 GTI HDI
Volvo V50 2.0d
Volvo XC90 D5
Haha what he said ^^^ Ok not him the one above!
Gt15's do not like high boost though, I think they overspeed very easily and self destruct. I think a K03 would be a better standard choice if you want something smaller as they are a little tougher, but they have all done 100k+ miles so most are getting a little too tired to be pushed.
GT2052s DTurbo
OEM+ HDI Estate
Project thread
No boost leaks still around 18 psi as before the intercooler was fitted. Maybe a bit more fuel low down will get it going better
(19-05-2013, 06:57 PM)Jimbo Wrote: No boost leaks still around 18 psi as before the intercooler was fitted. Maybe a bit more fuel low down will get it going better
get boost upped and more fuel, 18psi is Gay As Fcuk . . .lol
Yeah I plan on 22 24 ish once hg is done
(19-05-2013, 07:01 PM)Jimbo Wrote: Yeah I plan on 22 24 ish once hg is done
put it out of it's misery . . . Big Grin
A GT15 spools fast and runs out quick whereas a T2 come in later but punches harder. You'd have to find a way to fit it to an XUD exhaust manifold anyway as the GT15's came on HDi's... Unless you can swap the exhaust housings on the turbo's
3 x Peugeot owner.
1996 106.
1996 306 D Turbo S.
1994 Mercedes Benz 320E.
1997 306 GLX.
Gt15s came on xuds aswell.
I had a gt15 on my xud
306 HDI, soon to be XUD
(20-05-2013, 04:26 PM)declantg Wrote: I had a gt15 on my xud
My bad! GT15's were on XUD!
3 x Peugeot owner.
1996 106.
1996 306 D Turbo S.
1997 306 GLX.
Id run a GT15 over a T2.
Airflow isnt much odds up high acually, and you get a much cleaner / crisp drive.
But if your gunna change it, then put something better on Smile
  Worth a look if anyone's after a cheap D Turbo L95 12 7,940 11-08-2016, 07:05 PM
Last Post: L95
  How do you adjust a gt15 turbo jack123sand 6 4,943 09-06-2014, 09:47 AM
Last Post: toseland
  turbo timers? are they worth it? LewisG306 9 5,534 29-10-2013, 06:05 PM
Last Post: darrenjlobb
