Sachs friction plate part number
Question
Sorry for another clutch thread, ive looked through the others and im only after a couple of details.
1: the part number for the uprated sachs friction plate, paddle one i believe.
2: is it definitely available from ECP?
3: will it work with a standard LUK pressure plate and bearing?
Thanks
Ian
Dont no the part number but its on .net if you look on the clutch thred EDIT here it is 881861 999857
Can be bought from ecp well i ordered mine from there they got it in for me but never ened getting it due to changeing my mind and selling car.
I would use a valeo pressure plate and bearing as its tryed and tested to work not sure on the luk might work ok but dont no any one that has tried it
Awesome, thanks bud. As far as i know the valeo and LUK are the same, some have even had valeo labeled stuff in LUK boxes, so that should be fine.
Chris, i thought you went for the citroen berlingo clutch?
  CG Clutch - Paddle Vs Dual Friction pugtk 1 3,352 08-05-2019, 05:17 PM
Last Post: Frosty
  Sachs paddle Hdi and proud of it 9 6,896 01-11-2016, 08:07 PM
Last Post: Hdi and proud of it
  307 Crank seal Part number Daniel306 1 2,540 19-08-2014, 02:11 PM
Last Post: rryan
