Threads: 6
Car Model/Spec: Ph3 306 hdi
Given 0 thank(s) in 0 post(s)
Hey guys, my car (95 xldt) has been struggling to start over this past week or so, so i had the glow plugs changed yesterday and now it will not start at all.
it is turning over fine and smoking but just will not fire, the glow plug relay is clicking on and off like it always has done and should do so im clean out of ideas.
has anyone had this problem before?
thanks
ant.
Threads: 34
8
Given 8 thank(s) in 8 post(s)
Air leak in fuel lines somewhere
Threads: 6
Thanks guys, I have just slackend the bleed valve on the filter housing and nothing came out :/ should fuel come out of there? And one squeez of the primer and it's solid same as it always has been.
Thanks
.ant
Threads: 6
Well after trying all sorts we found that the plug relay was only giving out 6/9v to the plugs so we changed that an the car ran better than ever.............. Until today! Got to the car this morning and it's back to turning over an not starting, I'm beginning to loose my cool with it now as I can't afford to keep spending money on it and to top it all off the tax is due in 2 weeks.
Threads: 9
2
Short term solution is grab a jump lead and go from + on the battery to the top of the glow plug for 10 seconds then disconnect and quickly run to the key to start it. (Edit: Careful not to accidentally hit the block or you'll get a load of sparks, and it won't do your battery any good.)
Check the power going to the plugs again, you might have just got another dodgy relay. And also check the cabling, it could be loose or corroded.
Previous Car: VW Passat 2.0 TDi 140, 2005, 136,000 miles
Previous Car: Peugeot 306 XLdt (stock!), 150,000 miles (I miss this car
Threads: 7
0
Bud thers a post called td not starting thers literally everything in there u can try
