Steering boss
Rainbow
I'm just wandering will this boss fit my 306 hdi?
The reason I'm asking because I was told it was on a 306. But I'm not sure what phase it come of.
It has the bar piece coming out of the boss near the centre circule bit sticking out to?
[Image: pic3.jpg]
[Image: DSC02129.jpg]
The 'bar bit' is for self cancelling the indicators.
As for if it will fit, give it a go, as I believe the only difference it spline size. No way of telling that from those pics Smile
All 306's have the same spline size between phases. Same as the 106 too.
I've only changed a steering wheel with the horn on the steering wheel before. So then the wiring needed doing etc.
But on the 306 it has the horn on the stalk so will it still work or any changes needed to the wiring?
thanks.
Like you said the horn is on the stalk so no change.
(16-05-2013, 10:08 AM)Tom Wrote: Like you said the horn is on the stalk so no change.
Nice and easy nice one thanks.
If its the same spline size I see no issues with it Smile
Only issue would be airbag wiring, as long as there's a hole in the boss for the plug to fit through you'll be fine.
  Steering wheel boss MartinL 0 1,623 23-05-2015, 09:50 PM
Last Post: MartinL
  Wanted: Steering Boss / Wheel / Snap Off Kit MisterGTR 2 2,097 06-02-2015, 05:20 PM
Last Post: MisterGTR
  Steering wheel boss Slam Wagon 14 8,017 14-07-2012, 09:57 AM
Last Post: Ed Doe
