Loss of power steering fluid
So i get a call today from my other half, turns out her dturbo has taken a disliking to having power steering fluid inside the rack, and also decided why not sheer the PAS pulley bolt off for good measure.
I took the aux belt off so that we didn't end up with that wrapped around the crank pulley and drove it home.
My assumption is the rack is at fault which lead to the pump to run dry and sheer its bolt. But if anyone has any other ideas on what it might be something simpler i hope as i don't want to change the entire rack
Any help appreciated.
Also as a quick fix could i put a shorter belt on for the time being to keep the alternator running, using the original tensioner on an early ph1 xud engine (PAS at the bottom)
Something like this, (photo from Darren as only pic i could find with the right tentioner)
[Image: auxidea_zps2d87a8e9.jpg]
  Power Steering Pump, All The Same? bigcheez2k3 14 11,645 20-11-2020, 11:28 AM
Last Post: vento85
  Power steering rack.....replacement options Jellomanpie 9 9,317 30-04-2020, 05:54 PM
Last Post: Mighty306
  Power Sterering Ram/ Steering damper pugfrank 6 6,895 08-11-2019, 01:47 PM
Last Post: pugfrank
