What lowering springs
Are all the springs the same just different load ratings i.e, from 1.4petrol being low rating and 1.9-2L diesel high load rating.
I have a 1.9 dturbo and been offered some 40mm lowering springs but not sure if there off a petrol if they are would they fit but sit lower about 50mm-60mm instead of 40
NO SMOKE NO POKEBig Grin
The gti6 lump is heavier than the 1.9xud lump thats all i really know. Not sure on the hdi and the xsi engines :/
Gti and xsi are fairly similar weights iirc, as are hdi and xud, 1.4 and 1.6
(10-05-2013, 09:12 PM)vlj Wrote: Gti and xsi are fairly similar weights iirc, as are hdi and xud, 1.4 and 1.6
Are all the springs interchangeable not just HDi-xud and 1.4-1.6. Something like 1.4-xsi and gti-xud stuff like that. I'm thinking of getting some 40mm's tempereraly until I get coil overs. But if there off a smaller petrol would they still fit a xud just be softer and a bit lower than 40mm
If you got like 40mm 1.4 springs and put them on a gti you'd be more on 60mm drop? with bad handling due to the spring rates or something
[Image: mcetg0.png]
(11-05-2013, 12:02 AM)lolsteve Wrote: If you got like 40mm 1.4 springs and put them on a gti you'd be more on 60mm drop? with bad handling due to the spring rates or something
A right I get you. What about 1.8/2L petrol springs on a dturbo.
They'd probably raise it
1.8s are pretty light, XUD is heavier, GTi is heavier still lol.
If they're only temp, does it really matter? But if you're keeping them, just get the right ones for your engine lol. Smile
right there is some gti 6 60mm lowering springs near me for sale, will they fit my 1.4?
Rofl gti springs on a 1.4 would make it about 10x higher
Yeah like tom says dont put gti6 springs on a 1.4 i doubt youd get hardly any.drop due to weight.
As for the OP trust my dont put TU springs under an XU scary shit!! Fucks the handling lol
Sad Lowering Springs on stock shocks Moh 7 4,154 25-10-2015, 11:29 PM
Last Post: Jimmy-hdi
  cabriolet springs/gti6/lowering bad2vbone 1 2,135 25-02-2014, 11:22 AM
Last Post: bad2vbone
  Cheap lowering springs THE_Liam 24 12,358 15-01-2014, 03:17 PM
Last Post: kentiiboii
