Cutting boost holes!!
Anyone able to recommend a drill bit / piece / thing for cutting 3" holes in my chassis nice and easily for boost pipes to run through? Don't really fancy cutting squares and covering with spare rubber window/door seals!
Holes saw.
(07-05-2013, 11:37 PM)samass Wrote: Holes saw.
Thats the name then! I can look myself now I know what there called. Wink
But without the extra s
plasma cutter / hole saw / jigsaw if your feeling rash....
note, on mine i slid a silicon up over the hose where it went through to stop any knocking / protect it a bit.
(10-05-2013, 09:29 AM)darrenjlobb Wrote: plasma cutter / hole saw / jigsaw if your feeling rash....
Ordered a set of cheapy hole saws with sizes from quater inch up to 2 and a half inches I think.
I'll give them a go before anything! Smile
hole saw then jig saw to make the hole bigger. file off the edges then as darren says, piece of hose in the hole to stop rattles/damage to pipe Smile
  Flywheel has two timing holes? Fozzy 14 11,619 28-08-2012, 10:09 PM
Last Post: CJ_Derv
