07-05-2013, 08:27 AM
I need a 2.5 inch ally pipe with a T off for an 8mm pipe. Anyone know where I can get one? All I can find is one with a 25mm T off which is far too big.
![[Image: 20120704_212316.jpg]](http://i789.photobucket.com/albums/yy175/DanHargrave/20120704_212316.jpg)
Intercooler pipe with gauge take off.
07-05-2013, 08:53 AM
My top tip? Get a straight pipe and a tyre valve. Drill a hole, pop tyre valve through, remove core. Hey presto, one take-off.
Other option is to get one of these: Ebay clicky Pop a hole through a silicone hose and bolt this through. My intercooler system can hold up to 40psi with one of these with no issues.
07-05-2013, 09:14 AM
Thanks for that, I've just ordered one of them. Didn't realise you could attatch them to silicon, should be pretty easy to fit
07-05-2013, 09:19 AM
Very easy, and they seal well too when done up tight. I used a tyre valve for my LDA takeoff/boost gauge and one of those for my MBC.
lol christ thats expensive for what is effectively a bolt with a hole in the middle :p
07-05-2013, 09:20 AM
Aye but £10 is a hell of a lot cheaper than trying to find a replacement hard pipe with a nipple attached!
07-05-2013, 09:27 AM
yep that one on ebay is the best one i found!
07-05-2013, 09:46 AM
So that 1 ok eBay is it ok to put into a ally pipe?
07-05-2013, 10:02 AM
Seems so, it says it comes with both rubber and metal washers.
What i'd do is take a large hammer and flatten a section of the pipe so it's a flush fit
07-05-2013, 01:59 PM
I drilled and tapped a spare lda nipple onto one of the ally pipes, holds up fine
10-06-2013, 07:48 PM
Is the 1 on ebay the best option to go for?
| boost gauge pipe sizing | maxlee | 5 | 3,855 |
08-02-2014, 06:20 PM Last Post: Tom |
| Boost Gauge T-Piece for Bosch compensator pipe? | GP123 | 7 | 5,174 |
27-01-2013, 05:43 PM Last Post: Tom |
