Threads: 8
Car Model/Spec: ph1 gti6
My speedo is stuck and typically french blah blah.....i've taken them out and discovered that a fair few resistors are burn't out.
Now i'm just not sure wether to try and replace the resistors see if it works or get new clocks.
If i get new clocks i'm not sure if i'd just get the ph1 clocks or could have them from a different phase and how you get the mileage over. I've got a 97 ph1 gti6.
Just really stumped on what to do lol
My speedo is just stuck there and does little movements now and then..
Threads: 208
60
need a new speedo really . not worth messing around with
only ph1 dials fit. ph2/3 requier a major major rewire
Threads: 110
20
Car Model/Spec: Estate, DT, GTI6 and 205
Ive got a couple ph1 speedos out of S16s if there any good?
Threads: 6
1
slow down a bit? 170 is a bit excessive even in a 6.
do you have a pic of the board and we can see if its worth repair?
Threads: 8
Haha its fine no will notice i'm going that quick
I'll try and get a pic if i get time to take them out, cause they seem to be a bit more awkard in ph1 than ph2 n 3s
There were 3 resistors running on the side of the speedo, red ones with blue and white stripes. They were burn't out and another one on its own on the opposite side of the board burn't out same colour. I'll try and get a pic
But if s16 clocks will work, i'll take that and give that a go. How much are you wanting for them frosty??
Threads: 110
20
You would have to find out if the speedo is electric or cable drive. I would guess electric. I have got 1 on 97k or 135k i think thats what they are but will check.
£25 posted due to the price of postage
Threads: 8
Yeh its electric, i'll have the clock with 97k but i won't b able do anythin till friday, skint till then. I'll inbox you friday to sort it out if thats ok??
Threads: 110
20
yeah no worries i will check my 1 is electric
