WANTED: Stock Boost Hoses
Darren will vouch for me on this.
I need as many stock boost hoses as possible, I owe Darren I think 3 hoses now? And I need a few, I keep splitting them...
So anyone who has one spare, gimme, I'm happy to pay, and I'll be going down to the scrappies to get a few too...
Ruan xx
Pft, Man up and replace it with some more proper Wink But still please people find hoses, as I dont think theres a single XUD in my posession now other than my car that has a damn boost hose still on it!!
The turbo - ic hose? I think i have one. Cover the postage and its yours :-)
Ill go look
im pretty sure I've got 3 or 4 of these things id be happ y to let two go if you want them
Unless I go fmic, I can't see a way round... when I have money etc, I will for sure!
And defo yes to the others, ill pm you in a sec with details xx
Weld some scaffold pole together proper job ha ha won't blow that!!!
If I see any in scrappies I'll grab em
[Image: SDC10442-1.jpg]
How restrictive is the stock black hose? been thinking of getting a silicone hose to replace it, with a 2.25" diameter.
Seriously, think about what you just said.
arent the stock ones 2"?
padge Wrote:arent the stock ones 2"?
1 and 3/4" afaik
Sent from my HTC Wildfire using Tapatalk
[Image: sig-1.jpg]
SOLD
Won't it collapse a long peice of silicone though!!
stock pipes are fine...no smaller than the outlet on the compressor of most turbos you are running....
whats ruan on about then?
It can't be restrictive, it's on the compressed side, if it was going SMALLER than the outlet of the turbocharger, then it could be restrictive, but it's not...
Bigger =/= Better.
Ruan Wrote:It can't be restrictive, it's on the compressed side, if it was going SMALLER than the outlet of the turbocharger, then it could be restrictive, but it's not...
Bigger =/= Better.
It is, it goes from 2" off the turbo down to 1 and 3/4" then back up to 2"
[Image: sig-1.jpg]
SOLD
That stock boost hose is fine for 200hp+ so I really wouldnt worry...
The reason Ruan is having issues is nothing to do with it not being big enough, its just because his VNT sits at a funny angle, meaning the stock boost pipe dosnt fit correctly and is always sat at an angle, and over time of it compresses / expanding etc, it splits....
Bigger =/= Better.
It seriously isn't restrictive...
The air is compressed anyway... A GT35 uses the same 2" outlet off the turbo, if the outlet side was restrictive, don't you think it'd be a 3"+... dropping to 1 3/4" isn't going to restrict it at all on a pissy T2 or even a T25... If anything it's more area to fill at 2" all the way through, therefore more lag... Inlet side is a different matter entirely, but post compressor it makes no difference.
People have made 200+hp on that hose, I'm really not going to worry.
  WANTED: Boost Gauge Pod ct-hdi 5 2,812 11-04-2012, 03:00 PM
Last Post: ct-hdi
  Wanted: Boost gauge and fitting kit declantg 2 2,939 09-12-2011, 05:22 PM
Last Post: Midnightclub
