Threads: 115
Given 0 thank(s) in 0 post(s)
I know smoke on boost is a bad thing but what about the opposite, too much boost with too little fuel going in? I adjusted my MBC today on standard fuelling and found that I was able to make nearly 20psi at peak on standard fuelling. There wasn't that much more power but it was quite a nice setup is there any benefit to having more boost than you need to burn the extra fuel or should it be fine tuned into a tighter margin?
Threads: 143
10
Car Model/Spec: Ph3 XUD
Given 8 thank(s) in 8 post(s)
I'm not sure you can run more fuel than the turbo can boost, hence why some limit their boost by fuelling.
Threads: 386
87
As I understand it, too lean a mixture causes high cylinder temps, will cause more NOx emissions but I don't expect you're bothered by that lol. I'm not sure whether it'll be hot enough to cause any engine damage though.
Threads: 91
12
Car Model/Spec: 306 D Turbo
I don't see why you would want to, man up and add more fuel! Lol
Threads: 87
48
Car Model/Spec: Rouge vallelunga 5 door Dturbo
Given 74 thank(s) in 70 post(s)
boost without fuel is a waste, you are creating higher temps by the turbo spinning faster for no good reason . .
Threads: 226
24
Car Model/Spec: A3 TDi
But you need to fuel to make the boost in the first place... So without fuel there is no boost?
Threads: 87
48
(28-04-2013, 07:02 PM)Tom Wrote: But you need to fuel to make the boost in the first place... So without fuel there is no boost?
true i guess, but you can run different amounts of boost with the same fuel . .
Threads: 38
0
Car Model/Spec: d turbo s
what's the optimum smoke n colour a fine tuned engine should be ???
