procedure to adjust pump to suit engine
2.1 unit
i got this pump from a 1.9 xud
so what is the best procedure
ie max fuekl screw
lda spring
ramp
smoke screw on top
am thinking of fitting a pipe that shoots up gasses so i can see them in rear view mirror ...
the pump on my 2.1 has max fuel to the point where the revs are just starting to hang, throttle arm bent for more travel, gov mod, heavy lda grind, lda screw wound all the way out and the plastic bushes removed + inside of cap ground flat for more lda travel to aid off boost smoke. 9mm pump and a 2.1 engine is running approximately 150-160bhp with a little bit of clutch slip
(25-04-2013, 10:13 PM)ozonehostile Wrote: the pump on my 2.1 has max fuel to the point where the revs are just starting to hang, throttle arm bent for more travel, gov mod, heavy lda grind, lda screw wound all the way out and the plastic bushes removed + inside of cap ground flat for more lda travel to aid off boost smoke. 9mm pump and a 2.1 engine is running approximately 150-160bhp with a little bit of clutch slip
thanks for that
but what to do first how to recognise from smoke what to adjust
its easy to turn it all up and get loads of black smoke
I would recommend doing your basic fuel and turbo tune first. after that a gov mod would be next on the cards and then grind the lda pin to fine tune the setup
You need to adjust your blower too surely? About 20psi i'd aim for on a T2, but 18 to be safe.
S2 HDi >click<
154bhp
280lbs/ft
ok well trying to set this up now
disconnecting lda engine stationary
opening throttle slowly no smoke at any rpm
however when blipping throttle lots of black smoke ont he way up to rpm and down from rpm
lda is disconnected so what do i adjust
i was gping to connect a pipe on exhaust so that i can see more clearly when she was puffing out smoke etc loooks comical but works
Look in guide section bud
[Image: J5hxCcC.jpg]
What CJ said, Dan! did a cracking guide on pump set up and fine tuning
HDi Cabby Project Click
  Run out of diesel. Procedure? ASAP pls Dazecoop 8 4,527 26-01-2016, 01:22 PM
Last Post: Toms306
  How to adjust VNT stop screw ? andyyy 15 15,746 29-09-2015, 08:11 PM
Last Post: andyyy
  Bosch pump and engine setup bashbarnard 4 3,303 07-11-2014, 06:30 AM
Last Post: bashbarnard
