Cully's Bianca 6 R150 YVM
(09-11-2018, 12:01 PM)Eeyore Wrote: great work cully. What underseal and cavity wax are you using? what brand is the red oxide paint too?
COO-VAR Rust Converter, applied by brush, Source Local Molevalley farm suplliers
Teamac Red Oxide Primer Paint, applied by brush, Source Local Molevalley farm suplliers
Tetrosyl tetra schutz, appied by body spray gun Air powered, Source machine mart
TechniQ 900 Cavity Sealing Wax Protection Spray, applied by aerosol tin with a 500mm long spay Nozzel, source Ebay
GTI6 Info
cheers. im sure thatll come in useful when i finally look under the sideskirts.
Time to bring the post upto date
car has been SORNed since July
much work done!
all the outer sill welding plus retreating,
treat and paint all the under areas from the back valance to the fuel tank,
strip paint and treat all the inner sill areas under the car
replace all rear brake hard lines and compensatory
fit full set of HELL brake lines
replace all brake fluid to flush system
gearbox oil replaced
Engine serviced
AND TRACK DAY BOOKED!
things to do before track day
Tax car run it
Replace Brake fluid for competition Hi temp fluid
GTI6 Info
where is the track day? I need to get out more in mine Smile Would be good to get everyone on one track day this year,especially if FCS doesnt happen.
(13-01-2019, 03:09 PM)Eeyore Wrote: where is the track day? I need to get out more in mine Smile
Saturday 16th Feb castle combe booked through https://bhptrackdays.co.uk/
currently 14 cars booked on for full day
GTI6 Info
  cully's XU10J4RS cully 11 5,068 30-06-2016, 12:53 PM
Last Post: welshpug
  Cully's Electric car ..T project cully 144 47,427 16-04-2016, 04:14 PM
Last Post: cully
