xsara vts beem?
xsara vts beem?
Picking a beem up on payday off an xsara vts do these just bolt on?
From what I've heard they do
It's the same as a 306 one iirc. Just thicker torsion/arb bars
Not always the ARB, phase 2 VTS had a 23mm one
So they do just bolt on then?
No they don't. They are a pita, but don't worry I'll take it off your hands and save you the trouble
Yes, bolt straight on no issues.
Only difference is if you are mixing Ph2 to Ph3 as the Ph3 one has no load compensator as there's EBD done by the ABS ECU.
(23-04-2013, 10:28 PM)Matt Wrote: No they don't. They are a pita, but don't worry I'll take it off your hands and save you the trouble
Shut up meg!
(23-04-2013, 10:33 PM)Ruan Wrote: Yes, bolt straight on no issues.
Thanks dude Smile
If I Remember Correctly they also sit about 40mm lower as standard.
But exact same fitment, same 6 bolts connecting mounts
