Chirping!?
Hi guys,
Got an odd noise I'm trying to identify on the Vec....yes I know its not a HDi but it's near enough the same lol.
Basically, briefly (a second or so) on start-up, continuous under load up hill and breifly (a second or so) on low gearchanges (so slight load changing up at 1500rpm'ish say) theres a loud chirping noise. Loud enough to just hear with the window up.
Its not clutch slip as I always start the car with the clutch down.
It could be a belt slipping but if that was the case I should be able to replicate it at a standstill by loading the engine with the handbrake on and I can't.
Can it be diesel knock? Seems a bit specific though, and higher pitch than Im used to.
Only other thing I wondered is can a small air leak somewhere cause a chirp noise at the times I specified above?
Any ideas lol? Confused
Tom
Do these have a dual mass flywheel? Could be that my 110 hdi did it on its way out
[Image: 20gh7o0.jpg]
High load/rapid load changes shouldnt cause a belt to slip, so thats out. Would suspect something like the above, or possibly a pin-hole boost leak.
(22-04-2013, 01:02 PM)rd070707 Wrote: Do these have a dual mass flywheel? Could be that my 110 hdi did it on its way out
They do but mines only done 20k lol, shouldnt be broken yet, not sure how they would chirp though?
(22-04-2013, 01:40 PM)Poodle Wrote: High load/rapid load changes shouldnt cause a belt to slip, so thats out. Would suspect something like the above, or possibly a pin-hole boost leak.
Hmm, see if its a boost leak I'm not too fussed, probably blowing by the swirlflaps, or the EGR blank as theres only a gasket one side. Not sure how I can prove that its any of these things though. Undecided
Sell it
/troll
S2 HDi >click<
154bhp
280lbs/ft
(22-04-2013, 05:02 PM)Arron Wrote: Sell it
/troll
I will be. Smile
Just intrigued as to what the noise is lol.
To think i entered this thread with the intention of a "Get a vectra/" answer... Pahaha
Dual mass flywheels tend the squeak when you turn the engine off as they slow down.
But to answer your actual question.... I can aha. Its strange for it to do on start up and under constant load :/
(22-04-2013, 05:13 PM)Tom Wrote: To think i entered this thread with the intention of a "Get a vectra/" answer... Pahaha
Doesn't do it on shut off now you say that...
So looking more like an air leak somewhere then.
sell it
(22-04-2013, 05:34 PM)SRowell Wrote: sell it
Wanna buy a vectra?
http://www.youtube.com/watch?v=M4oFl5s9OzM
thats what mine sounded like
Yeah thats what my Golf one sounded like on shut off now I've seen that lol
But thats a definite squeak, this is a chirp, I'll see if I can get a vid, but my phone camera is shocking lol.
blow of valve?
run over a budgie?
(23-04-2013, 08:53 AM)cully Wrote: run over a budgie?
I think that'd be more of a 'squealch' than a chirp. lol
It could be an engine mount tom. Have you tried grabbing your engine and pulling it back and forth
S2 HDi >click<
154bhp
280lbs/ft
Sure it's not epic wheelspin from the hugely torquey GM lump?
I know the engine mounts are f*cked, or atleast one is. It always happens after a clutch/DMF change as they let the engine rest on the mounts I guess, seen/heard about the same thing loads. Didn't know they could chirp though?
I've taken a vid, but my phone camera is crap, but if you listen hard you can hear nothing, then one or two chirps, then it becomes almost constant. It's difficult to hear from the vid though
http://www.youtube.com/watch?v=pMLcrAce_...e=youtu.be!
Some kind of tensioner somewhere? :/ Is it like chirpchirpchirpchirp fairly quick in that video? Like you say its really hard to hear :/
Alternator/alternator belt. Search it on vec-c. Very common.
Sounds like a tensioner to me. Or it's a bird you can hear in the video and you're therefore whinging about nothing.
finally got a bird in your car tom? :p
(23-04-2013, 09:21 PM)SRowell Wrote: finally got a bird in your car tom? :p
FLOL, does sound belt / tensioner related don't have much luck with cars do you mate :/
Team Doesn't own a 306
(23-04-2013, 11:01 AM)cwspellowe Wrote: Sure it's not epic wheelspin from the hugely torquey GM lump?
No thats more 'chchchchchchchch' as one wheel slips......only drivers one oddly, why they didn't leave TC in the facelifts I have no idea, wouldn't be an issue at all then! Rolleyes
But I know you were taking the piss. Tongue
(23-04-2013, 07:53 PM)JJ0063 Wrote: Alternator/alternator belt. Search it on vec-c. Very common.
Keep getting told off by PM on Vec-c lol. Itwasntme
So I've been avoiding it since. Apparently starting a breaking thread about a Peugeot in the 'local' section was a bit naughty...
Then I was moaning about Vectra's which is apparently not allowed. lol
But I'll have a look then....
Yeah but she shat everywhere and left worms on the passenger seat. Undecided
Oh and Sam....it was a black bird. Confused Oh sorry, a blackbird. lol
Luck? What is this 'luck' you speak of? Doh
are you sure it wasnt you who shat everywhere
(24-04-2013, 09:28 AM)Just Sean Wrote: are you sure it wasnt you who shat everywhere
Not on the passenger seat, I dont tend to drive from there....
  "Chirping" Aux belt C.A.R. 7 6,332 08-08-2012, 10:08 PM
Last Post: lolsteve
