Threads: 169
91
Given 1 thank(s) in 1 post(s)
The 1.8 engine was turbo charged and used by peugeot in rallying. Are you sure they have got their facts straight?
Threads: 82
27
4k before custom management? A 2.0 bottom end would be easier to buy forged parts for, but i'd of thought you could do a turbo build including management and mapping for 5k if you do most DIY.. even cheaper if it was S/C
or.. forget going forged, buy some uprated bearings and a decomp plate and see how much power it'll take? save yourself 1k on forged internals...
Threads: 29
Car Model/Spec: 306 2.0 8v Turbo
Given 2 thank(s) in 2 post(s)
New heater matrix came yesterday. £32.39 from euro car parts. Now to start putting the dash back in.
As for the engine and management side of life i may just leave it for a while till i can make a definate decision on what to do.
Still kind of like the Pulsar GTIR engine option, its a strong unit with the potential for big power, i can get a complete engine, ecu and loom for £700.
Still got loads to do to the shell in the meantime.
Going to drop it by 40mm and go mad on the powerflex
1999 2.0 8v Turbo 306
You Tube: 832 Performance
Threads: 82
27
200SX engine cheaper? they're essentially the same
Threads: 29
The 200sx is mounted inline, the Pulsar GTI-R is transverse, according to my nissan mate guru couple that with a sunny gearbox as the GTI-R box is 4wd and it is a good set up. Obviously lots of custom bits would have to be made, but i dont think it will cost 5K. Most of the mechanical stuff i can handle. mating the Nissan and Peugeot wiring looms could be a mission though.
Threads: 91
83
You're better off using the XU engines - they're slanted for one, if you stick a SR20 in, you're going to f*ck the handling...
The XU 16vs are better flowing engines than the SR20 as standard, forged up they're equally as strong - remember they used the XU10 staying relatively standard in Rallycross producing 500+hp with restrictor rings... And 300hp+ Naturally Aspirated in Group A...
(16-05-2016, 10:45 AM)Toms306 Wrote: Oh I don't care about the stripped threads lol, that's easily solved by hammering the bolt in. Nanstone GTD5 GT17S - XUD9TE
Threads: 29
Such a shame G Tech Motorsport are not about anymore.
Cheers for the advice
Threads: 29
12-12-2013, 08:38 PM
(This post was last modified: 12-12-2013, 08:44 PM by PUGNUT_XS.)
Threads: 29
Started to prep the LH side of the engine bay today.
Threads: 169
91
awesome progress dude!
Threads: 29
engine bay is all now de-rusted and primed. A good army buddy of mine has got me this 2 stage rubberised based paint and anti corrosion sealant that they use on the military vehicles, My car will never rust again
Threads: 29
Ok, Engine bay is all done now.
Recieved the big end bearings and main bearings today, collecting the thrust washers from Peugeot tomorrow.
Waiting for a clutch kit, once that arrives, sending the bottom end off to connaught engineering to have it blueprinted.
Having gearbox dramas at the mo as you can see on my other thred. Waiting for the supplier to get back to me. Basically my gearbox came with the reverse cable cut off and no gear lever lift.
Will post some pics soon.
Threads: 169
91
Love this project. Got any more pics dude?
Threads: 29
09-01-2014, 02:05 PM
(This post was last modified: 05-11-2014, 09:38 PM by PUGNUT_XS.)
(09-01-2014, 08:25 AM)Grant Wrote: Love this project. Got any more pics dude?
Got quite a few to upload, will do them soon. On a good note while the engine is being bluprinted he has looked at the pistons and reackons that he can safely machine 4 thou out of the crown to lower the compression and as long as i dont run anymore than 1 bar of boost the bluprinted internals will take a turbo all day long.
I wanted a turbo from the start, the biggest drama will be fitting a turbo, there has to be a way of doing it without spending £1800 on a DP set up.
Threads: 169
91
Result that
This has so much potential to be an epic car. Well more epic than it already is turning out to be.
Sub £1800 would be realistic if you did most or as much of the work as possible yourself
Threads: 31
4
Car Model/Spec: tu5 bitza/cherry dt
Given 5 thank(s) in 5 post(s)
As above, this could turn out to be a totally epic car, keep up the hard work
Threads: 29
The main bulk of the surface rust was around the ABS pump area. but its all sorted now.
[attachment=12626]
[attachment=12627]
[attachment=12628]
[attachment=12629]
[attachment=12630]
[attachment=12625]
Looking much better than before.
Threads: 169
91
This thread gets better and better. Great progress mate. Shaping up really nicely
Threads: 29
As i am going to go down the turbo route, i have decided to use the GTI-6 engine, got the main bearing shells in today, although the thrust washers do not look the same as the ones that came out, but the Peugeot dealer assures me they will be fine.
[attachment=12631]
[attachment=12632]
[attachment=12633]
[attachment=12634]
Threads: 82
27
As awesome as turbo would be.. can't help but think you'd save a shit tonne of cash doing a charger setup instead
Threads: 29
10-01-2014, 08:26 PM
(This post was last modified: 10-01-2014, 08:35 PM by PUGNUT_XS.)
(10-01-2014, 08:20 PM)Grant Wrote: This thread gets better and better. Great progress mate. Shaping up really nicely
Cheers mate
I am really looking forward to taking it to some events once its finished.
(10-01-2014, 08:24 PM)Midnightclub Wrote: As awesome as turbo would be.. can't help but think you'd save a shit tonne of cash doing a charger setup instead
Looking at the prices of everything both options with me doing all the work come out almost the same, both around the 4k mark(That's just in Parts) if i use off the shelf components. Chuck the emerald at £700 plus mapping its going to be around the 5k mark.
Once i get the head and block back together and in the car, i can start playing around at fabricating a exhaust manifold.
Threads: 581
195
Given 81 thank(s) in 77 post(s)
Supercharging can be so much cheaper than 4k but if I had the choice, I'd go down the turbo route. Much more fun!
Check end float when you get the crank back in. Most miss that and can be quite bad sometimes!
Threads: 29
(10-01-2014, 09:00 PM)Niall Wrote: Supercharging can be so much cheaper than 4k but if I had the choice, I'd go down the turbo route. Much more fun!
Do you have the tolerances anywhere, i only have the ones that are in the haynes toilet paper. Not sure if they would be the same as the standard 2.0 16v.
Threads: 581
195
Quote:The Peugeot specification for end float is between 0.07 and 0.27mm
Threads: 29
(11-01-2014, 04:38 PM)Niall Wrote: Quote:The Peugeot specification for end float is between 0.07 and 0.27mm
Many thanks
Threads: 3
Threads: 29
Threads: 29
[attachment=13074]
[attachment=13075]
Threads: 226
24
Car Model/Spec: A3 TDi
Its in, wahoo!
Threads: 29
More pics of putting the crank back in.
[attachment=13200]
[attachment=13201]
[attachment=13202]
[attachment=13203]
[attachment=13204]
