Heater blower resistor
Hi Guys,
Heater blower has just stopped working one morning. I've been advised to check the heater blower resistor and after taking out the air feed cover over the blower, the hole where you access the resistor is all sealed up on my 306. has anyone come across this before? Need to get to the resistor pack to check it because it's getting rather cold in my car Sad
Before you check that check the relay. Where your fuses are under steering wheel. Its a green fuse on top row. Usually yhat which goes. If its stuck it its blown and melted
What do you mean sealed up? Can you get a picture always helps in these situations.
What phase is your car aswell?
(17-04-2013, 01:05 PM)kentiiboii Wrote: Before you check that check the relay. Where your fuses are under steering wheel. Its a green fuse on top row. Usually yhat which goes. If its stuck it its blown and melted
That's one thing I never checked. I'll take a look at them soon.
Cheers bud
It was the relay! Replaced with another one not in use and the blowers are back on. Thanks Tom.
(23-04-2013, 08:53 AM)lazareth1 Wrote: It was the relay! Replaced with another one not in use and the blowers are back on. Thanks Tom.
Thanks tom?
Your welcome
Thanks tom?
Your welcome
f*ck I'm a complete c**k. Sorry I meant you Kentii. Can you forgive me? How do I rep ya? Tongue
I'm having the same issue: heater blower works only on low speed regardless of the position of fan speed controller. I have checked the fuses and they are all good. Have taken out the fan controller box and could not find anything wrong in there (no burnt marks or black resistors on the pcb board, etc).
Where exactly is that relay that you have changed and fixed your heater blower speed problem? Cheers!
I have a 306 cabriolet 1994 1.7l manual. Thanks again.
Under the scuttle panel, passenger side, under the plastic grill.
  Heater blower issues Dturbo john 5 5,821 13-03-2018, 01:53 PM
Last Post: Toms306
  Heater Blower Issues MY95 7 7,659 06-03-2018, 11:22 AM
Last Post: Magenta Sunset
  Heater blower problem Pingaz 7 5,424 04-06-2016, 01:19 PM
Last Post: Pingaz
