camshaft
how hard isit to change a cam on a xud? im pretty sure you just have to
1. put the locking pins in the flywheel and pump
2. release belt tension
3. undo the 3 rocker cover bolts
4.undo the 6 bolts that hold the cam in place
5. put the new cam on
then bolt it back down then
6. put every thing back together not forgetting to do the timing onit
can anyone confirm if this is correct or not
thanks loads to any good advice
andy Smile
need to remove the vac pump and cam pulley.
also replace cam seal.
also imo worth once cam removed turning crank back half turn until you replace the cam and time the cam up...otherwise you may push a valve into a piston!
(16-04-2013, 06:18 PM)Piggy Wrote: need to remove the vac pump and cam pulley.
the cam im replacing it with already as a pulley on so i should be fine yeh?
Yeh defo make sure you do this, else you'll find because the cam could be in any position that you end up bolting it down into the valves/pistons. You'll more than likely snap the cam first though :p valves are stupidly hard to bend when they're sat vertically, normally only done with starter/inertia, but yeh make sure you rotate the motor back 90 degrees to clear valves and then figure out position later.
Isnt the cam slotted in one end though...so need to remove pulley to pull cam out?!
Dont need to remove the cam pulley, just the rocker cover and camshaft braces.
ah righto....just done the 2.1 head so confusion there
  HELP! - 306 DW8 Possible Camshaft Seizure? jamesgmg 22 16,222 07-02-2013, 03:39 PM
Last Post: Mattcheese31
