Threads: 151
14
Car Model/Spec: 306 D-turbo
Quite a few people bypass the standard filter and put a inline one in
Team Doesn't own a 306
Threads: 226
24
Car Model/Spec: A3 TDi
You should check the tank strainer aswell if your having issues like that.
Threads: 15
Car Model/Spec: 306 xrdt bosch max fuel 28 psi
checked and cleaned strainer nothing in there clean as hell so i could get a little fuel filter that attaches between the fuel line and that will do the job ??
Threads: 130
82
Car Model/Spec: 106 GO-NAD
Common one to use is one off an Audi tt. Can get them from halfords for about 7 quid. I've done it on mine
Threads: 541
124
Could be clogged lines, try some fuel system cleaner or a tank of veg if you have a Bosch
Threads: 90
54
If the filter is new, then obviously theres a problem somwhere as it should be fine, you can use any filter you want provided its a decent filter, dont just use literally one of them pissy little inline go kart spec things, because thats not gunna be up to it.
Are you sure its starving ( a vacume) or might it just be sucking air somewhere?
Threads: 15
yer i had a air leak in system but it still feels flat and everynow then will get a stutter so i thought well if i take out filter and put one somewhere else would work better lol
Threads: 130
82
3.2 petrol, its pretty sizeable
Threads: 141
35
i ditched the inline fuel filter and went back to a standard one as it looks tidier and you still have the fuel heater and swirl pot thing.
Threads: 130
82
I just rest mine on the top rad hose. Warms it up enough! It's also next to the exhaust downpipe, so that helps too. Cold starts aren't an issue even on 100% veg
Threads: 141
35
(10-06-2013, 12:12 AM)samass Wrote: I just rest mine on the top rad hose. Warms it up enough! It's also next to the exhaust downpipe, so that helps too. Cold starts aren't an issue even on 100% veg
never thought of that! but still, I personally prefer the oem filter housing in my pursuit of a tidy engine bay
