Sp alloys information
Can't seem to find much info on these.. I have a set 16".
What width are they? Offset etc? We're they original Peugeot ones or not? What tyre size do I need for them? 205's?
Any info appreciated!
At a guess they'll be 6.5j et19 ish should tell you on the inside of the wheel
Youll want 195 45 16 tyres
And yes they are original pug wheels, came with the sp pack
Ran 205/45 on mine
The reason id run 195s is because thayll get you closer to oem rolling radius
Would 195's stretch a bit then? And they're wider than cyclones then?
Cyclones are 6j.
Na you wont get any stretch with 195s, if you want a bit of stretch go for 185s
So would 205's be a bit too much then? Sorry if these are daft questions Wink
Youd get away with them I think but ideally you want 195s
Ok cheers!
195's are ever so slightly stretched. You saw the 195's on my alloys didn't you? They are exactly the same.
GT2052s DTurbo
OEM+ HDI Estate
Project thread
Okay.. I wanted to get Yokohama parada spec 2 tyres.. But they don't seem to do them in 195 45... Will 205 make that much difference? :/
205's would be better imo.
GT2052s DTurbo
OEM+ HDI Estate
Project thread
No youll still get them on, im just not sure what width the sp's are.
Go with there is hardly any difference between 195 and 205s just 195s are closer to oem rolling radius
Pretty sure theyre 6.5" and the difference is only 10mm... Personally Id be getting 205s
205/45 is closer to oem rolling radius than 195/45
Ok, so 205 would fit ok and look 'right'..
(15-04-2013, 08:11 PM)Ricky Wrote: 195's are ever so slightly stretched. You saw the 195's on my alloys didn't you? They are exactly the same.
Sorry mate just seen this comment hahaha, yeah I did, there was a bit of stretch wasn't there
When I next get a set of tyres I will be getting 205's. Only got 195's because they were a bargain.
GT2052s DTurbo
OEM+ HDI Estate
Project thread
ordered 205 tyres Smile parada spec 2's Smile
  masks information please dr_jekyll 8 3,850 16-11-2014, 09:51 PM
Last Post: Slam Wagon
