lost boost and now cant get it back
hey guys my pug was boosting at like 28 psi nicely then gardually losing psi now down to 16psi on max boost i have taken off all my turbo pipes checked every one for splits etc.. and put them back on nice and tight but no diffrence the d seal isnt leaking on tmic or anything so u turned up my turbo some more today. and now its at 20psi but i have no more thread left on my actuator arm any help would be great thanks guys Smile
Is your turbo screaming for its life? When did you last change your fuel filter?
Wastegate creeping?
Does it smoke?
^^^^if it doesnt...fueling would be my bet
it smokes when flat chat going up a hill or summin fuel filter is what 10miles old i was thinking actuator as it has no more thread left on the arm
i can hear my turbo whistling checked turbo no play in it spins nice and freely no nasty sound
Dose it feel like you got no boost? Not a faulty boost gauge is it?
does this have anything to do with your other huge fueling issue maybe?!?!?
lol
hahah no got boost can feel the pull and still spins in second but its gone lol ;(
so no play, makes no bad sounds, still pulls hard yet you think your turbo has gone?
if it still pulls hard look at boost gauge or try the hose that goes to the gauge
I would seriously sort out your fueling issues first
fueling sorted now backed off the fuel because of the black smoke but yer no noises nothing just dont have the boost there im gna check the boost gauge pipes later just to ask where has everyone put there piping to go into the car ???
Theres a hole in the bulkhead behind the master cylinder and behind the battery but lower down on the bulkhead - thats the one i used.
S2 HDi >click<
154bhp
280lbs/ft
perfect thankyou i got like 3 meters and went down the passangers door skin through the door loom etc ahhaha might be better to do that haha
  FMIC 20 psi running temps & boost held back by the lucus puglove 11 7,513 24-08-2012, 04:56 PM
Last Post: puglove
