Estate taillight removal
As above how is it done need to swap my drivers side one for a new one
flap at the inside back open it you should find two or three finger bolts undo and pull cluster from the outside
There's a thumbscrew on the outside of the light when you open the boot, and another thumbscrew behind the removable trim at the side of the boot
Then just pull thanks guys ill sort that in my break
